Keihin FCR39MX carburetor.
Irezumi aka Reuben
Carrot Top
PostPosted: 22:28 - 07 Feb 2009    Post subject: Keihin FCR39MX carburetor. Reply with quote
I am looking to buy this carb for my bike. I have found them new for just under £400 or on ebay for various prices second hand.
If I were to buy one that was from another bike would it fit my Suzuki DRZ? I assume it will be the same carb as they were also fitted to KTM's, Yamaha' and all sorts, or will mounting points etc be different?
Thanks for any help.
Ichy
PostPosted: 23:50 - 07 Feb 2009    Post subject: Reply with quote
Only ever had experience of Mikuni. There are no bike specific mounting point on the carb simply because the same carb is used on many different bikes. The only work I've had to do generally relates to manifold size or very simple mounting brackets.
PostPosted: 01:14 - 08 Feb 2009    Post subject: Re: Keihin FCR39MX carburetor. Reply with quote
As above. can't see there being different mounting points as carbs are pretty much just mounted by the airbox and rubber going to the engine. I believe I have this carb on my CCM and I don't believe there's anything bike-specific about mine.
I thought you said you'd be happy with the power Razz Wink.
Irezumi aka Reuben
Carrot Top
PostPosted: 11:50 - 08 Feb 2009    Post subject: Reply with quote
The power is enough, the fuelling however is fairly poor and there is the option to either re-jet the current Mikuni or replace it with the Keihin (which is considered a lot better), along with opening up the air box.
Having said that I might change the cams and get a big-bore kit as well! Razz
The last post was made 17 years, 63 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.18 - MySQL Queries: 14 - Page Size: 39.1 Kb
