| Cigaro |
 Cigaro World Chat Champion
| Itchy |
 Itchy Super Spammer
 Posted: 12:52 - 13 Feb 2009 Post subject: |
It'll make it run lean, a very very cheap and bodge tastic mod is to put some gaffer tape over the carb inlets or over the air filters to restrict the airflow and it riches it up a bit.
Babyyam's Eliminator the IL4 carb bike had this...
On my NTV the guy who bought it first thing he did was angle grind the zorst off big hole it in anyway and put some beetle chrome exhausts on the down pipes where the zorst used to attach to.
He opened up the air filter and taped up 1/4 of the air filter riching it up again.
At your own risk though. ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| Cigaro |
| Kickstart |
 Kickstart The Oracle
 Posted: 13:01 - 13 Feb 2009 Post subject: |
Likely to have strange effects. Quite likely to make it run lean, but could also cause odd issues with the length (and how pressure waves bounce up and down the exhaust) and land up with it lean in some places and rich in others.
Mixture screws basically change the idle mixture and have little to no effect elsewhere. While the risk would be when the engine is under load, which would likely be on large throttle openings (and could result in a hole in a piston).
| 0ddball |
 0ddball World Chat Champion
| Itchy |
 Itchy Super Spammer
| Cigaro |
| yambabe |
 yambabe World Chat Champion
 Posted: 13:14 - 13 Feb 2009 Post subject: |
Itchy is right, I briefly had a 400 Eliminator that we had erm lets just say some problems with! One of which was that the airbox rubbers had shrunk so badly that I ended up putting aftermarket K&N-style filters on it, then even after re-jetting had to resort to gumming them up with silicone to try and get the mixture right.............
Biggest thing about riding the 250 with no end can IIRC would be the vibration and subsequent white-finger lol, I had to get it welded a couple of times and without the can on it got very very buzzy.......... ____________________ Sod falling in love, I wanna fall in chocolate.  |
| Cigaro |
| Kickstart |
 Posted: 13:34 - 13 Feb 2009 Post subject: |
You need to figure out where it is lean and where it is rich and from that determine which jets to change and in what direction.
Eg, a random dyno run for my Bandit:-
https://www.alfa-pages.co.uk/TempPicture/Bandit1200Dyno.jpg
From the graph at the bottom you can see it is running a bit lean until just under 7k and gets a bit rich at the top end (OK, the richness at the very top is probably from backing off the throttle). To "fix" this leanness at the lower end (although in this case it is too close to bother about) might mean lifting the needle up a touch, but that would probably make it too rich at the top end. Or maybe really richen it up on the mixture screws which would probably make it far too rich on idle. Real solution would be to change the needle profile for a more suitable one, which isn't really a realistic option without a large pile of needles.
What I mean is that you could find that the bike is generally lean from (say) idle to 4k, then rich from 4k to 5k, and then lean again above that. And no simple change will make it better everywhere.
| Cigaro |
 Posted: 13:43 - 13 Feb 2009 Post subject: |
Is there a way to do it without a dyno?
And how do I change the carb needle settings?
Sorry for the stupid questions  |
| Kickstart |
 Posted: 14:11 - 13 Feb 2009 Post subject: |
Well, you can just guess but the chances of guessing right are limited.
Needles can normally be shimmed up to richen the mixture they control. Aftermarket (eg, Dynojet) and some standard needles often are located with a small circlip in one of several grooves, and you move the clip to a different groove to change the mixture they control. They are also likely to be a different profile chosen to more likely match the requirements of the bike they are sold for when in some state of tune.
| The Shaggy D.A. |
 The Shaggy D.A. Super Spammer
| Stelmer |
 Stelmer World Chat Champion
The last post was made 17 years, 234 days ago. Instead of replying here, would creating a new thread be more useful? |
