klr 250 stalls when in gear
ausswharfie
PostPosted: 03:42 - 24 Feb 2009    Post subject: klr 250 stalls when in gear Reply with quote
85 klr 250 starts @ idle's fine, as soon as you stick it in first gear it just cuts out. has never done this before, always been good to ride only used for trail ridding in state forrest. fuel flow seems ok,spark ok, any idea's
brad.
PostPosted: 12:17 - 24 Feb 2009    Post subject: Reply with quote
Side stand safety switch?
Try by-passing that.(usually just a case of joining the wires together)
DRZ-400sm
steve32
PostPosted: 12:32 - 24 Feb 2009    Post subject: Reply with quote
+1 Thumbs Up
suzuki GSX 600F katana .: ~my bike up for sale~ :.
CBT = Completed
DAS= Working on it - theory test = Passed
lonner
PostPosted: 12:33 - 24 Feb 2009    Post subject: Reply with quote
as above or you can give it a shot of wd40 and free it of as the salt plays hell with them Thumbs Up
you might need to hold the pin with pliers and work it in and out a bit to loosen it fully hth
4Stroke
PostPosted: 14:08 - 24 Feb 2009    Post subject: Reply with quote
Yeh sidestand switch.
You can remove the two wires and solder them together to prevent it happening again. If you don't want the added safety feature it brings that is...
Failing that then the clutch is not disengagion properly but I'd defeinitely go with the above posts imo. I'm just thinking out loud.
PostPosted: 14:59 - 24 Feb 2009    Post subject: Reply with quote
Might also be the clutch switch rather than the sidestand switch. Which remarkably can be stripped and cleaned on Kawasakis.
4Stroke
PostPosted: 15:20 - 24 Feb 2009    Post subject: Reply with quote
What do you find remarkable about that? (That may sound bluntly argumentive but I'm actually generally interested about why you find that remarkable Thumbs Up )
ausswharfie
PostPosted: 02:13 - 25 Feb 2009    Post subject: klr Reply with quote
thanks for all the info, it was the clutch switch wires had worked loose, it's fine now
PostPosted: 02:37 - 25 Feb 2009    Post subject: Reply with quote
Because there are very few electrical parts on modern Japanese motorcycles that can be dismantled and fixed. If they are faulty, you are expected to just buy a new one. Especially switches. Most of them are made in such a way as attempting to dismantle them either damages the housing rendering the part useless or are simply impossable to dismantle at all.
The Kawasaki clutch lever switch is an exception to this, it can be totally dismantled, cleaned and reassembled.
I have old, Eastern European motorbikes which even have relays that can be dismantled and repaired.
Fuel taps are another classic in a similar vein. They used to unscrew so you could clean them out, now they are rivetted.
4Stroke
PostPosted: 10:41 - 25 Feb 2009    Post subject: Reply with quote
Big Thumbs Up for Kawasaki then.
I guess the more modern stuff is more prone to the unservicable/sealed parts also?
The last post was made 17 years, 209 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 65.63 Kb
