ZXR750 Idling issue
Wise1
PostPosted: 21:09 - 03 Mar 2009    Post subject: ZXR750 Idling issue Reply with quote
My ZXR750 has a (hopefully) small idling issue.
Sitting at around 200rpm it just about runs ok without stalling and you can rev it no bother.
If you turn the Idle screw so its sitting at about 1000rpm it's fine until you rev it, when you do it keeps on going by itself up to about 4000rpm and wont come back down.
If you unwind the idle screw more than you wound it it will eventually come back down.
Anyone got any ideas?
Current - 2007 Suzuki Bandit GSF1250 - 1999 Suzuki TL1000R
Previous - GSXR750 SRAD, Fireblade, ZXR750, CBR600
Bikeless
PostPosted: 21:35 - 03 Mar 2009    Post subject: Reply with quote
At a guess i would say something to do with the throttle linkages on the carbs sticking but it is a guess.
Wise1
PostPosted: 23:26 - 03 Mar 2009    Post subject: Reply with quote
Well it's more than I had to go on Mr. Green
DaveH
PostPosted: 01:28 - 04 Mar 2009    Post subject: Reply with quote
Does the throttle snap back ok - I am assuming that it does, then it would preclude the cables, which would hold it at constant revs, not increase.
Not sure if an airleak somewhere would cause this, or have the carb tops been off recently - it could, at an outside chance, be that the needle piston thing has got the hole blocked so is not closing back down properly - air leak may be best bet.
https://www.timhastingsracing.co.uk/
ZX7R & ER6F
lonner
PostPosted: 08:48 - 04 Mar 2009    Post subject: Reply with quote
hi
you say you are adjusting the tic-over with the screw Question
the carbs have a remote adjustment knob or im pretty sure they do Thumbs Up
so to me this looks like you are adjusting these carbs with the balance screw adjuster on the linkages and this would cause the running you describe i might be wrong but would like to see a pic of the adjustment screw you are turning to clear this up Thumbs Up hth
4Stroke
PostPosted: 09:58 - 04 Mar 2009    Post subject: Reply with quote
ZXr's run two throttle cables, one for opening and one for return(closing).
It is probably the return throttle linkage/cable has become stiff.
I took mine out recently because of this problem and I now experience similar issues to your self until I take one off my other machine.
TUG
PostPosted: 03:51 - 05 Mar 2009    Post subject: Reply with quote
Pics would help, and the revs shoot up when you return the throttle? Possibly a carb balancing issue? Maybe thats what your turning, a butterfly sync screw? We need pics tbh.
Haz ER-5, innit!
Wise1
PostPosted: 22:43 - 05 Mar 2009    Post subject: Reply with quote
Putting a video up, just to be clear, will post link a min or two.
wizzzard
PostPosted: 22:51 - 05 Mar 2009    Post subject: Reply with quote
I had what seems to be exactly the same problem with mine about a month ago now.
I stripped the carbs and cleaned them followed by balancing and now it runs perfectly.
wizzzard
PostPosted: 22:54 - 05 Mar 2009    Post subject: Reply with quote
Almost forgot i did oil both throttle cables at the same time.
Wise1
PostPosted: 23:49 - 05 Mar 2009    Post subject: Reply with quote
https://www.youtube.com/watch?v=TtpF25du3Vc
Bit long but you get the idea.
DaveH
PostPosted: 00:25 - 06 Mar 2009    Post subject: Reply with quote
How much slack is in the throttle cables, try backing the tension right off to see if that settles it any
ZX7R & ER6F
Wise1
PostPosted: 00:32 - 06 Mar 2009    Post subject: Reply with quote
Ok, cheers Dave will try that Thumbs Up
wizzzard
PostPosted: 00:39 - 06 Mar 2009    Post subject: Reply with quote
exactly how mine acted before the i tackled it
TUG
PostPosted: 01:05 - 06 Mar 2009    Post subject: Reply with quote
If it was me i'd do what youve been told and oil up the cables, re-set the throttle cable tensions, check the choke isnt sticking and lube that up, then balance your carbs and your bike will then benefit alot and throttle response will be fresh an smooth. If you have a mate who can do it get him/her to do it its well worth it.
Haz ER-5, innit!
MaybeGuy
PostPosted: 01:09 - 06 Mar 2009    Post subject: Reply with quote
sticky choke?
Wise1
PostPosted: 01:11 - 06 Mar 2009    Post subject: Reply with quote
Cheers folks, will try those suggestions Thumbs Up
BanditsHigh
Worse than a woman
PostPosted: 10:06 - 07 Mar 2009    Post subject: Reply with quote
What he actually means is that I'm going to get the carbs out and give them a good clean and the cables as well ... then I'll re-install and balance them for him Smile
Should've done it before I let him buy it Embarassed
Thom
PostPosted: 17:32 - 07 Mar 2009    Post subject: Reply with quote
Wish there were more sellers like that! Smile
The last post was made 17 years, 165 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.62 - MySQL Queries: 13 - Page Size: 101.99 Kb
