| Wise1 |
 Wise1 World Chat Champion
| Bikeless |
 Bikeless World Chat Champion
| Wise1 |
 Posted: 22:26 - 03 Mar 2009 Post subject: |
Well it's more than I had to go on
Cheers ____________________ Current - 2007 Suzuki Bandit GSF1250 - 1999 Suzuki TL1000R
Previous - GSXR750 SRAD, Fireblade, ZXR750, CBR600 |
| DaveH |
 DaveH World Chat Champion
 Posted: 00:28 - 04 Mar 2009 Post subject: |
Does the throttle snap back ok - I am assuming that it does, then it would preclude the cables, which would hold it at constant revs, not increase.
Not sure if an airleak somewhere would cause this, or have the carb tops been off recently - it could, at an outside chance, be that the needle piston thing has got the hole blocked so is not closing back down properly - air leak may be best bet. ____________________ https://www.timhastingsracing.co.uk/
ZX7R & ER6F |
| lonner |
 lonner Spanner Monkey
 Posted: 07:48 - 04 Mar 2009 Post subject: |
hi
you say you are adjusting the tic-over with the screw
the carbs have a remote adjustment knob or im pretty sure they do
so to me this looks like you are adjusting these carbs with the balance screw adjuster on the linkages and this would cause the running you describe i might be wrong but would like to see a pic of the adjustment screw you are turning to clear this up hth |
| 4Stroke |
 4Stroke Scooby Slapper
| TUG |
 TUG World Chat Champion
| Wise1 |
| wizzzard |
 wizzzard World Chat Champion
 Posted: 21:51 - 05 Mar 2009 Post subject: |
I had what seems to be exactly the same problem with mine about a month ago now.
I stripped the carbs and cleaned them followed by balancing and now it runs perfectly. ____________________ And did you exchange a walk on part in the war for a lead role in a cage?
Zeitgeist / Addendum / Moving forward |
| wizzzard |
 Posted: 21:54 - 05 Mar 2009 Post subject: |
Almost forgot i did oil both throttle cables at the same time. ____________________ And did you exchange a walk on part in the war for a lead role in a cage?
| Wise1 |
 Posted: 22:49 - 05 Mar 2009 Post subject: |
https://www.youtube.com/watch?v=TtpF25du3Vc
Bit long but you get the idea. ____________________ Current - 2007 Suzuki Bandit GSF1250 - 1999 Suzuki TL1000R
| DaveH |
 Posted: 23:25 - 05 Mar 2009 Post subject: |
How much slack is in the throttle cables, try backing the tension right off to see if that settles it any ____________________ https://www.timhastingsracing.co.uk/
ZX7R & ER6F |
| Wise1 |
 Posted: 23:32 - 05 Mar 2009 Post subject: |
Ok, cheers Dave will try that  ____________________ Current - 2007 Suzuki Bandit GSF1250 - 1999 Suzuki TL1000R
| wizzzard |
 Posted: 23:39 - 05 Mar 2009 Post subject: |
exactly how mine acted before the i tackled it ____________________ And did you exchange a walk on part in the war for a lead role in a cage?
| TUG |
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 00:09 - 06 Mar 2009 Post subject: |
sticky choke? ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| Wise1 |
 Posted: 00:11 - 06 Mar 2009 Post subject: |
Cheers folks, will try those suggestions  ____________________ Current - 2007 Suzuki Bandit GSF1250 - 1999 Suzuki TL1000R
| BanditsHigh |
 BanditsHigh Worse than a woman
 Posted: 09:06 - 07 Mar 2009 Post subject: |
What he actually means is that I'm going to get the carbs out and give them a good clean and the cables as well ... then I'll re-install and balance them for him
Should've done it before I let him buy it  |
| Thom |
 Thom World Chat Champion
The last post was made 16 years, 331 days ago. Instead of replying here, would creating a new thread be more useful? |
