| Xanthic |
 Xanthic Borekit Bruiser
 Posted: 14:55 - 07 Mar 2009 Post subject: So what do you do when... |
...you've WD40'd, taken off the fairing around it to get complete back and front access to it... but STILL cant get the nut off to remove the fairing?
NSR 125 R1 2001, left hand bottom fairing under the left front indicator  ____________________ First & Current: Honda NSR 125 R1
Link fixed - https://apopandagumshield.wordpress.com |
| Itchy |
 Itchy Super Spammer
 Posted: 15:04 - 07 Mar 2009 Post subject: |
Is it rotating when you undo it? , ie the brass nut (usually covered in rubber) has seized? , try some pentrating oil then mole grips on the brass bit (hard as the brass bit is completely round) while undoing the fairing bolt.
If it doesn't come out you get a nut spliter thing for £5 and split the brass thing.
If its in a place where you can't get a nut splitter in like my Africa on its screen bolts I sawed the off, but in doing so generated so much heat it melted the fairing slightly. ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| Xanthic |
 Posted: 15:21 - 07 Mar 2009 Post subject: |
| stirlinggaz |
 stirlinggaz World Chat Champion
 Posted: 22:03 - 07 Mar 2009 Post subject: |
hi,
i removed a fairing bolt from a cbr the other day.
was seized pretty solid.
got out the dremel & smallest cutting disc.
making sure i didnt cut the plastic, i cut a slot in bolt head & removed the offending bolt with a huge,flat bladed screwdriver.
(maybe the vibrations off the dremel loosened it slightly, but it slackened with a satisfying "crack".
if that hadnt worked, i was going to grind the head of the bolt off, with the pointy grinding stone attachment, remove the fairing & thenremove the leftover bolt stub by cutting a slot in it & using the screwdriver, or molegrips.
worked for me numerous times.
if your going to do this, surround the area with masking tape, so the sparks dont mark the paintwork.
cheers,
GAZ |
| Xanthic |
 Posted: 19:58 - 10 Mar 2009 Post subject: |
| stirlinggaz wrote: | hi,
cheers,
GAZ |
Gaz rules! ____________________ First & Current: Honda NSR 125 R1
The last post was made 17 years, 217 days ago. Instead of replying here, would creating a new thread be more useful? |
