Tried to fix the GPZ today and made a hash of things....
c_dug
PostPosted: 01:31 - 13 Mar 2009    Post subject: Tried to fix the GPZ today and made a hash of things.... Reply with quote
Firstly a nice simple one, any tips for fitting a split link o-ring chain, im having alot of trouble with the o-rings and getting the whole lot squished enough to get the split link on, ive just borrowed a G clamp to give that ago but other than that im all out of ideas, any suggestions/tips?
Secondly, my breaks siezed up from sitting outside and not being used much, I've never worked on sliding caliper brakes before and managed to get in a bit of a muddle with the re-assembly, i spent the best part of an hour getting the damn things back together, there was some type of metal clip/bracket in the bottom that was a pain to get seated (i doubt that makes sence without seeing it)
Anyway now ive lost all break pressure completely which is quite a worry, i havent lost all the fluid so im at a loss as to whats gone wrong, my only guess is that ive gone badly wrong on the re-assembly, unfortunalty my haynes is a little sketchy on the front brake, well either that or the more likely thing, im an idiot Laughing
So any suggestions/thoughts on what may have caused the loss in pressure?
cheers
c_dug
SoND
PostPosted: 07:56 - 13 Mar 2009    Post subject: Re: Tried to fix the GPZ today and made a hash of things.... Reply with quote
Get a small nut that sits over the thing and clamp with vise grips
PostPosted: 08:06 - 13 Mar 2009    Post subject: Re: Tried to fix the GPZ today and made a hash of things.... Reply with quote
Make sure you don't have it too tight. Fit the split link with the joining part of the chain on the sprocket, not hanging in mid air. Make sure you aren't trying to fit the split link clip onto the rivet link (the split-link has a groove round the end of each pin for the clip to go round)
It's "brakes" not "breaks". Wink
How far did you strip them? Did you pump the pistons out? If so, did you top-up the brake fluid as you did so? Might have pumped air into the system.
This might help. This is the same calliper design, just a mirror image of your one (off an older model that had the disc on the opposite side).
https://www.bikechatforums.com/download.php?id=63852
c_dug
PostPosted: 10:36 - 13 Mar 2009    Post subject: Reply with quote
Laughing My brakes wern't pumped whiles't off so i cant figure out why the loss in preassure, it's the anti rattle spring that i think i've got wrong, i think. Confused
Basicly i think i got it all back together alright, I couldnt work out what was supposed to be keeping the pad that sits against the pistons in, there didn't appear to be any sort of pins or anything, the anti rattle spring looked as though it had two tabs which extended round onto the edge of the pad to secure it, is this right do you know?
Oh and im definetly not trying to fit the split link over rivots, im not that bad Laughing
c_dug
PostPosted: 11:55 - 13 Mar 2009    Post subject: Reply with quote
Are the pistons moving when you pump the lever?
It is held in place by a mixture of luck and wishfull thinking.
It can't come out or move once fitted because it is trapped between the piston, the calliper bracket and the disc.
The same can't be said for the rear one which if near the end of its wear and being used on a worn disc, can be spat out.
Cigaro
PostPosted: 12:13 - 13 Mar 2009    Post subject: Reply with quote
Just bleed your brakes and they should be fine.
As stinkwheel says, there are no pins or anything to hold the pads in. When the calliper is on the disc, it is held in place by those two little metal retaining clips, and can't fall out because the disc is in the way.
The 'anti rattle spring' is the small metal plate (never knew that's what it does, though, but I assumed it was important Very Happy), on mine (looks like the same calliper design except mine is single piston) there's a little tab that sits against the bottom of the outside pad.
Attached paint diagram might make more sense. Anti rattle spring shown in blue.
Cigaro
PostPosted: 12:18 - 13 Mar 2009    Post subject: Reply with quote
A better one showing the other pad, disc (in black) and the 'little metal retaining clips' i was on about.
Note that the tabbed edges of the other pad fit underneath the retaining clips.
Cigaro
PostPosted: 12:21 - 13 Mar 2009    Post subject: Reply with quote
You'll know when you've got it together right anyway. It doesn't really 'look' right any other way.
SoND
PostPosted: 14:53 - 13 Mar 2009    Post subject: Reply with quote
Seal in the mastercylinder can go when you push the piston back in.
Cigaro
PostPosted: 15:38 - 13 Mar 2009    Post subject: Reply with quote
Would say it was unlikely to be that, though. Especially if you've not noticed any leaks. As I say, just bleed it up and it should be OK.
c_dug
PostPosted: 00:37 - 14 Mar 2009    Post subject: Reply with quote
Some brilliant stuff here guys, thanks.
It certainly looked right when i put it together which is why i was puzzled when there was no pressure at all, i guess bleeding the brakes is the next step then.
I'll keep you posted.
thanks again
c_dug
SoND
PostPosted: 16:26 - 14 Mar 2009    Post subject: Reply with quote
https://www.bikechatforums.com/files/clip_190.gif
Jesus Junky, lern 2 paint. I hope this picture is a little bit clearer. Wink
Sorry, I meant the spring in the mastercylinder can go. Happened to me once. Sad
c_dug
PostPosted: 10:38 - 15 Mar 2009    Post subject: Re: Tried to fix the GPZ today and made a hash of things.... Reply with quote
First things first, this...
...has got to be one of the most useful things anybody has ever told me to do Thumbs Up big thanks for that one Thumbs Up
So, the chain is on, the brakes however are not so good.
Last night i rode the bike round to my friends house (the_godfather off here) and we stripped the brakes down, what a mess! I obviously made a cock up of things with the rattle spring so thats bent to buggery, unfortunatly thats not the worse problem.
The dust seals hav come out mayby 75% of the way around one piston and 50% around the other one, after lots of trying we couldnt get them back in so they are now out completely.
We also noticed that the smaller of the two brake pistons doesnt come out when the brake lever is squeezed, is this because of its size and something to do with pressure or is it because its buggered?
Also when we removed the brake reservoir we discovered some not so healthy looking brake fluid, we flushed this out and replaced it with fresh fluid, the normal pumping the lever technique doesnt seem to be working so well to get the new fluid through to the caliper, there is nothing, or very little, coming through at the bleed nipple, without a syringe to suck the fluid through what is the best way of getting the fluid fully through the system?
So basicly just to summerise...
1) Why would the larger piston move alot further than the smaller one?
2)What is the best technique for getting the brake fluid through the system without a syringe.
Oh and the bike is at the_godfather's at the moment, he might have a look today in which case expect any replys to be from him and not me.
Thanks again Karma
c_dug
PostPosted: 11:05 - 15 Mar 2009    Post subject: Re: Tried to fix the GPZ today and made a hash of things.... Reply with quote
1) Because it has less friction from the seals compared to its surface area and therefore moves more readily when the fluid pressure increases. The path of least resistance. As long as the small one moves when the big one stops against the disc, that's fine.
2) I'd leave it sat with the nipple open and fluid in the reservoir for 10-15 minutes to start with.
Then I'd try bleeding it the traditional way except only cracking the nipple open very breifly every third pull of the lever (so "pull, pull, bleed. Pull, pull, bleed").
If this doesn't start getting pressure up, try bleeding the banjo bolt at the master cylinder (wrap a cloth round it to stop fluid going everywhere). They sometimes airlock at this point, once fluid is coming through without air, try at the nipple again.
c_dug
PostPosted: 15:39 - 15 Mar 2009    Post subject: Re: Tried to fix the GPZ today and made a hash of things.... Reply with quote
[quote="stinkwheel1) Because it has less friction from the seals compared to its surface area and therefore moves more readily when the fluid pressure increases. The path of least resistance. As long as the small one moves when the big one stops against the disc, that's fine.[/quote]
With a clamp on the bigger of the two pistons the smaller one did move Thumbs Up
Something that i dont understand is that there was plenty of pressure to start with, then i took the calliper apart and cleaned it out however i am certain that no seals were broken at this stage, then i re-assembled the calliper and there is no pressure, how could air of got into the system like that?
My dad suggested that some sort of seal on the master cylinder may have gone, i cant remember which one. Im guessing its easier to clearly describe what im finding over the phone than on here so mayby he's right, any suggestions as to what seal he was on about and any thoughts on the idea?
c_dug
The last post was made 17 years, 180 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.37 - MySQL Queries: 13 - Page Size: 94.44 Kb
