Terminology - clutch 'free play' and 'release mechanism'
issey9090
PostPosted: 19:53 - 15 Mar 2009    Post subject: Terminology - clutch 'free play' and 'release mechanism' Reply with quote
Slightly confused about the terminology -
Is clutch play the distance the lever is pulled in before clutch is in use i.e. the movement where its doing nothing?
Basically my clutch lever doesn't suit me at the moment - resulting in stalls and bad slow movement control - the bikes i used on my training felt much smoother.
The clutch on my bandit only engaged when let out quite far, almost to full, so i have used the adjusters at the lever and the top of the clutch box and it now seems to engage about half way let out, so much better. The problem now is i find the distance between the biting point and full engine engage is too small, and would like to make this larger... I think that makes sense-
At the moment:
biting point.......fully engaged.................................lever out
Desired:
biting point..............................fully engaged...........lever out
Is this adjusted using the release mechanism?
Thanks for the help
PostPosted: 19:58 - 15 Mar 2009    Post subject: Re: Terminology - clutch 'free play' and 'release mechanism' Reply with quote
Not sure what you mean by 'release mechanism'.
Clutch free play usually means the amount the lever moves before it start to 'pull' - so basically the 'loose' bit where the lever can just waggle.
Not sure what you mean by 'release mechanism'. You might be able to get the point where the clutch slipping to be enlarged, but I suspect probably only maybe by fitting softer springs. External adjustments will pretty much move both points about the same (slight differences due to linear/circular movements.)
If you keep using it like it is, I suspect you will probably get used to the sensitivity required soon enough.
issey9090
PostPosted: 20:04 - 15 Mar 2009    Post subject: Re: Terminology - clutch 'free play' and 'release mechanism' Reply with quote
Thumbs Up thanks for clearing that up. The haynes manual says the 'release mechanism' can be adjusted for the clutch, but doesn't really go into what it does.
I've had it for 2 weeks, but maybe i will get used to it...
Thanks Cool
The last post was made 17 years, 188 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.05 - MySQL Queries: 14 - Page Size: 37.53 Kb
