| Chriss |
 Chriss World Chat Champion
| Chriss |
 Posted: 18:00 - 16 Mar 2009 Post subject: |
No one able to help me?  ____________________ TheShaggyDA: I've got 3 or 4 pairs that predate my wife, so at least 11.5 years old. |
| MarJay |
 MarJay But it's British!
| Chriss |
| MarJay |
| Slinn84 |
 Slinn84 Scooby Slapper
| TheDonUK |
 TheDonUK World Chat Champion
 Posted: 21:35 - 16 Mar 2009 Post subject: |
Run some Redex through it,
Also what is the condition of the exhaust like? is it leaking anywhere? ____________________ [Current Bikes - GSXR-750 K5 & C90-97 ] [Previous Bikes: Runner 125, YBR 125, GS500, Bandit 600, Hornet 600, ZX6R-99, C90-99, R1-99, XT600E-04, GSXR-750 K4, CRF250L '16] |
| MarJay |
| veze |
 veze Trackday Trickster
 Posted: 19:03 - 17 Mar 2009 Post subject: |
my gs500 didnt realy have a silencer, it made it have need a lot of throttle to go anyway but there were no flat spots ever, just pulled and pulled and pulled.
now. id start with a service. 75% of ''carberation'' problems are ignition related anyway. change plugs.
check that the ht leads are well pushed into there plug caps and coils. if you take your tank of the ignition coils are inside the top of the frame just below the headstock.
there should be two coils, one for each cylinder. check for obvious damage and corrosion, but to be honest these are very well built machines, despite being built to a budget.
once youve got you new pulgs, and everything is firing nicely take it for a spin. if it isnt that then its carb related or maybe a bit of feul starvation.
check your feul tabnk breather.
give your carbs a good clean an blow out with and air line, and make sure the pilot jets are screwed it well bit do not over tighten. mite be worth taking the gauze out of you tank and give that a clean and swill you tank out while your at it.
If there is and in-line filter going from your feul tap to your carbs it mite be worth replacing that, to be honest i would do that first, because they can cause you sooooo much agro if there blocked and you dont think of checking them.
good luck and let me know how you get on
cheers,
josh. ____________________ tlm50,mt5,sr50. rs125 extrema, cbr 400rr nc29 suzuki gs500e.Honda cbx250 rs . FJ1200 .fz6,fjr1300 |
| veze |
| Chriss |
The last post was made 17 years, 223 days ago. Instead of replying here, would creating a new thread be more useful? |
