Pit bike troubles - just won't run :(
squishio
PostPosted: 21:11 - 20 Aug 2009    Post subject: Pit bike troubles - just won't run :( Reply with quote
video of me trying to start it....
https://www.youtube.com/watch?v=Pj2shM_v4qQ
On every couple of kicks it will backfire and shoot the kick start back into my leg which is fun, then after a couple more kicks it'll start run disgustingly then stop and pop backwards.
pretty much the sequence in the video.
I have just fitted a new Molkt 26mm carb but think the problem lies elsewhere as it was the same with the old mikuni 22mm carb.
A passer by who noticed my frustration suggested that the problem was the coil without any doubt. could it be? makes sense to me as maybe the spark is sparking at the wrong times?
I have had the spark plug out and there is definitely a good spark.
cheers!
Rich
Engine - Demon 140cc
Current - Hornet 600, Transalp 650, X140 Pit, GPZ400R
Past - SY125, GT250, GT650, CX400, CBF600, Bandit 600, SL1000, GT250
Dr. DaveJPS
PostPosted: 21:32 - 20 Aug 2009    Post subject: Reply with quote
it sounds like ignition timing, possibly the spark is firing on the exhaust stroke.
not sure how you adjust it on coil ignition though.... (sorry i can't be more useful) Thumbs Up
www.davejps.com
Billing
PostPosted: 21:35 - 20 Aug 2009    Post subject: Reply with quote
My TZR did something similar, the plug looked fine, but was failing in the cylinder, try a new plug, it fixed my problem straight away Smile
spitfire123
PostPosted: 18:37 - 21 Aug 2009    Post subject: Re: Pit bike troubles - just won't run :( Reply with quote
cheers!
Rich
hi mate,
i had the 140 version....you shoudl fion that the magnito is ajustable....1st check that.
if not your tappets are horribly out.
as with the carbs that youve changed the mikini carb is much better quaklity than thecheapo molkt carb...so id stick with that.
good luck mate,
need any more help contat me!
You won't be able to eat my dust......As it'll settle before you get there.
The last post was made 17 years, 36 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.18 - MySQL Queries: 14 - Page Size: 41.38 Kb
