Honda NSR125 1993 barrel & piston question
atomiccomp
PostPosted: 20:03 - 04 May 2009    Post subject: Honda NSR125 1993 barrel & piston question Reply with quote
Hi all, and thanks in advance for any answers I might get!
I have a honda NSR and after I bought it it broke down. I compression tested it and there was only 5psi! I removed the piston and barrel and its goosed good style, the bore is scored deeply with 1 straight line and the bottom ring has embeded itself into the piston and top ring.
My question is this; Is the bore chrome plated on that year, and if it's not is it possible to re-bore, or could I pop a new piton and rings in and carry on running it?
Regards
Mike
the serial/chasis no is hi*jc20*226838
alains
PostPosted: 00:45 - 05 May 2009    Post subject: Reply with quote
before thinking top-end rebuild , check the status of the conrod especially the side play with blade gauge .it shoudnt be more than 0.5mm (limit is 0.6mm) . afterwards if conrod ok you can buy :
- barrel-piston kit
- set of rings
- piston pin,small end bearing,clips
- base cyl. seal , cyl. head gasket , oil seal (valves shaft)
total cost around £200 vat inc
https://www.davidsilverspares.co.uk
ph : 01728833020
The last post was made 17 years, 61 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.07 - MySQL Queries: 14 - Page Size: 31.41 Kb
