California Superbike School
vt6
PostPosted: 18:14 - 09 May 2009    Post subject: California Superbike School Reply with quote
Hi ladies / gents
Anyone been to this or know anyone that has? Is it worth the money for the benefit?
PostPosted: 18:17 - 09 May 2009    Post subject: Reply with quote
Yes I've done it (Level 1) , and for me it did give a lot of benefit. G has also done it and was not so impressed (level 1)
Why do you want to do it? To improve on the road or track?
McGee
O RLY?
PostPosted: 18:19 - 09 May 2009    Post subject: Reply with quote
I hang out/ride with a guy that's an instructor at the Kevin Schwantz Suzuki School thingy.
Apart from the fact it costs close to $1,800 I have heard and seen some god awful riders come off the course and be much better riders.
Still cheaper to get your own bike and take it to a track and learn like that Laughing
Its pronounced Jixxer!
vt6
PostPosted: 18:29 - 09 May 2009    Post subject: Reply with quote
Track mate, done Ron Haslam and a handful of track days. Getting more into it each time. Just wanting to improve, not ruling racing out if i get half decent.
PostPosted: 18:34 - 09 May 2009    Post subject: Reply with quote
Well, level 1 is designed for the track, and it is reputed to be way better than Ron 'Experience day' Haslam. For me who hasn't done anything like that before (except trackdays) it was like switching a light on in my head. I was a LOT quicker afterwards.
However, G found being that he was already pretty quick it didn't help him to improve that much. He is planning to do level 2 soon though and I think that might be more aimed at his level.
PostPosted: 19:06 - 09 May 2009    Post subject: Reply with quote
VT6 I figured it would be better to do a more complete reply here than to reply by PM so other people can read it. You start off with a briefing and there are six classroom sessions and five track sessions. You are allocated an instructor for the day who leads/follows on each of the track sessions and he gives you feelback on how you are doing on each drill.
The first thing they teach is Throttle control. They make you ride around the track in 4th gear, and open the throttle as you go through the corner. Its a bit basic perhaps but its the first building block that you use in the level 1 system. It sounds a bit too basic, but as I said it does work for me.
The second thing they teach is turn in points. They put some X's on the track with yellow tape to show you where you should be turning in. For me this was a LOT later than I was expecting and it was a bit weird. It makes you ride slower as you concentrate on where the turn marker is. They tell you to avoid using the brakes in this excercise.
The third lesson is quick turning, and they ask you to stick to two gears and not to brake beyond what is required for confidence. This is effectively a counter steering drill and is good. They take the yellow X's away so that you have to imagine where your turn in points are. Its a lot easier than it sounds.
The fourth session is on not upsetting the bike with too many rider inputs. Its really a smoothness drill. They ask you not to brake at all, and you have to remember where your turn in points are and use your hard countersteering to get the bike over. If you don't you end up running wide.
The fifth and final session is like an intro to level 2 and it teaches you to use all of the things you have learned so far, along with where you should be putting your eyes as you go through a corner.
As I said, if you listen to it described like that it sounds a little ropey, but they have to do it like that so everyone starts on the same level. You cannot do level 2 unless you've completed level 1 and so on, so theres' no point trying to book level 2 or above if you think you're a good rider. You have to go through the whole system and I can completely see why.
I hope this answers your question! Smile
vt6
PostPosted: 19:14 - 09 May 2009    Post subject: Reply with quote
Cheers for in depth write up mate. From that it sounds like if you do track days it may be similarish stuff but as you say if you have to do it before progressing then it gives a complete instruction from the start sort of thing.
Paivi
PostPosted: 10:45 - 10 May 2009    Post subject: Reply with quote
The second thing they teach is turn in points...They tell you to avoid using the brakes in this excercise.
The fourth session is on not upsetting the bike with too many rider inputs. Its really a smoothness drill. They ask you not to brake at all...
Eh?
The first session we had was 3rd gear (apart from us V-twins, who were told to stick to second) and no brakes.
The second session was turn in points, but using brakes.
Third session was any gear you wanted, using brakes.
Fourth session was again any gear, using brakes.
I have mixed feelings of the CSS level 1 day I did. On the plus side, I had one on one tuition, as I missed most of the first session due to fogging, and I learnt a lot about the bike's and my own capabilities. On the negative side, one of the group members should not have been allowed to join, as she was dangerously slow, only speeding up on the two straights, but slowing down to 10-15mph in 60mph chicanes, causing chaos in her wake. She didnt' improve at all during the day, and we all felt she should have been encouraged to call it a day.
I didn't continue to level 2, as I wasn't sure it was value for money, especially as people like that girl would be allowed to take part, having taken part in level 1 and there not being a 'pass' or 'fail' system of progression.
PostPosted: 13:13 - 10 May 2009    Post subject: Reply with quote
I guess the actual gear and stuff is dependent on the track and the bike. I was at Rockingham on my Buell. Also, I'm going on the notes I took and the details in the little booklet they gave me. The Tuition is one to one, and I remember my instructor ('Cookie') telling me to change slightly what Andy Ibbott said in a couple of sessions. The detail doesn't matter. What matters is that you get a feel for what is involved.
Paivi
PostPosted: 14:25 - 10 May 2009    Post subject: Reply with quote
I did mine at the Stowe Circuit at Silverstone. Tuition was definitely not one to one, most people shared their instructor with 2-4 other riders. I was special... Wink
PostPosted: 09:37 - 11 May 2009    Post subject: Reply with quote
I wouldn't worry about it until you're struggling to go faster by yourself.
Just spend the money you would have spent on that on more trackdays IMO.
The last post was made 17 years, 158 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.28 - MySQL Queries: 14 - Page Size: 75.44 Kb
