tuning my 50cc supermoto
adamcpi50sx08
PostPosted: 22:25 - 13 May 2009    Post subject: tuning my 50cc supermoto Reply with quote
i got a cpi supermoto 50 totally standard except from i have added a slighty bigger jet and changed the sprockets because the old ones were part of the restriction, the bike tops out at 45-47mph, i have been told that i should get a race exhaust because the stock cpi exhausts are still restricted inside the expansion chamber, a racing air filter and jets to suit, i have also been told by a different person a racing exhaust and a bigger carb(you get a racing filter with the carb) will make it a bit quicker but my dad sed that a bigger carb will over fuel it and damage the engine somehow, is any of this right and do any of you have any suggestions to make it a bit quicker, i know its only a 50cc but i only want a extra 10mph or so
if it helps im running 13 front and 52 rear sprockets
CR 125 (OFFROADER) - DEP PIPE ETC
CPI 50 SX 2008 - NO MODS YET EXCEPT FROM A SET OF ACERBIS HANDGUARDS
Hutchysrs50
PostPosted: 23:12 - 13 May 2009    Post subject: Reply with quote
Jolly moto race exhaust
big bore kit
19mm / 21mm carb
racing stator/pickup with coil to match
a good K&N filter
racing reed valves + block if ya like
racing crank, polished + stuffed webs
Ta-da
Gilera SC 125 - Current
Hutchysrs50
PostPosted: 23:14 - 13 May 2009    Post subject: Reply with quote
or
dont get a K&N filter, there pretty naff actully.
get a decent exhaust and upjet the carb, 13t sprocket should be enough, put a 14 on if you want more top speed and slower acceleration.
putting a bigger carb on, with a restricted exhaust and standard cylinder isnt a good idea, and unless you set it up rather well, probly wouldnt run anyway. Thumbs Up
adamcpi50sx08
PostPosted: 10:44 - 14 May 2009    Post subject: Reply with quote
i dont want to fit a big bore kit because im only on a cbt and they do actually pull us over and check the bike over up here and i dont want to chance getin done for no licence or insurance when i actually do have one, do you think a decent exhaust, perfect or nearly perfect jetting and maybe a set of racing reeds and block will do much and i hear that all the aftermarket airfilters (k&n, doppler etc) suck water when it rains and make the bike run very bad but i have found two doppler filters that probs wont suck water if i position them properly, what do you think
https://www.adrenalin-pedstop.co.uk/ThumbnailGenerator/default.aspx?File=979eb538-afe7-4172-9e3c-2c0ed237577a.JPG&width=230&height=230
https://www.adrenalin-pedstop.co.uk/ThumbnailGenerator/default.aspx?File=701cd056-43fd-4431-b7a2-cf817cd34e07.JPG&width=230&height=230
and also whats this about drilling holes into the airbox lol
c_dug
PostPosted: 10:57 - 14 May 2009    Post subject: Reply with quote
Your licence restricts you to 30mph anyway...
c_dug
adamcpi50sx08
PostPosted: 11:22 - 14 May 2009    Post subject: Reply with quote
yes but i think its a bit easier to tell that the bike goes quicker when its got a big bore kit etc and also that will void my warranty where if i just add the pipe etc i can remove them and refit the stockers for warranty repairs, also i dont want to spend stupid money on my 50cc when its gonna be gone by the end of the year when i go for my a2 licence
element
PostPosted: 11:48 - 14 May 2009    Post subject: Reply with quote
adamcpi50sx08 wrote:
... i dont want to spend stupid money on my 50cc when its gonna be gone by the end of the year when i go for my a2 licence
dont bother tuning it then.. save the money. seriously..
04' DT125RE (run-a-bout) // 89' DT125R (rebuilt + supermoto conversion)
SPARES FOR SALE. 2RK TZR // 82 DR125 // DT125R/E .... PM ME...
Hutchysrs50
PostPosted: 15:23 - 14 May 2009    Post subject: Reply with quote
Drilling holes in the airbox just lets more air pass through it, having the same effects as a K&N filter.
if you ha ve a supermoto bike with an open K&N filter, if rain goes on it, it will ovbs be sucked into the engine.
i wouldnt bother with the reeds/block personaly, as there quite sensitive, dont think they make that much differnce anyway.
personaly, if it was my bike...
i would get a race exhaust (any aslong as its a straight through pipe(
put a bigger front sprocket on by 1 size, and upjet the carb about 4 sizes than the one thats in.
Finglonga
PostPosted: 17:30 - 14 May 2009    Post subject: Reply with quote
Following you down the road at anything over 30mph is a bit of a giveaway that it is no longer a moped and is now a motorbike.
Andy Sez....
F.Y.Y.F.F.
Theoutsider
PostPosted: 17:48 - 14 May 2009    Post subject: Reply with quote
Oh yes they do.I changed the reeds on my other bike (RS50) and it made the difference.
Theoutsider
PostPosted: 17:56 - 14 May 2009    Post subject: Reply with quote
Get a exhaust,go for an arrow or jolimoto.With the standard exhaust you have progresive speed,with a race exhaust the engine will stay reved even if you change a gear up.As long as you don`t have electric restrictors don`t bother.Get a bigger sprocket 14 tooth like hutchyrs said.Buy a box of jets.Get a 21 mm carb.buy few spark plugs if it runs well after you jet it take the spark plug out,see how it is like.If it runs fast don`t be fooled it could run lean or rich.I think it should do a top speed about 60.In my opinion nearly 50 mph it is fine.Don`t mess up with a 50cc.The bigger the tuning is the more unreliable will be.I used to change rings every 2000 miles with my rs.Also you don`t have to change the crankshaft if you are planning to keep the standard cylinder.Don`t go for a big bore,you will regret it.Keep the standard airbox,don`t go for fuckin` k&n faho&fahf.The best performance is the standard one.Good luck
Safetyman73
PostPosted: 07:31 - 16 May 2009    Post subject: Reply with quote
CPI do a kit for this bike as my sons was done the front sprocket is 13 the rear 51 new jet for the carb and a new front pipe thats all it entails. If i remember the kit was £148 all in.
Hth
Eddie
PostPosted: 10:38 - 16 May 2009    Post subject: Reply with quote
Hth
Eddie
That just sounds like de-restriction to me.
adamcpi50sx08
PostPosted: 22:04 - 17 May 2009    Post subject: Reply with quote
yes that is the cpi derestriction kit, so is there no way that a properly jetted 21mm carb will harm my engine or its reliability with out a big bore cylinder kit etc
tutton
PostPosted: 22:19 - 17 May 2009    Post subject: Reply with quote
Depends a 21mm carb still not jetted and oil pump compensated for the more fuel will damage your engine, badly.
adamcpi50sx08
PostPosted: 22:30 - 17 May 2009    Post subject: Reply with quote
i think i'll leave the carb actually becuase i dont really want too blow it up lol, do you guys think a doppler reedblock will be much different to the stock or will mine be the same if i just fit the doppler reeds
tutton
PostPosted: 22:32 - 17 May 2009    Post subject: Reply with quote
Reeds are the same
your playing with the air-fuel mix which is as bad as the carb
and could still blow it up if you give it too much air making it run lean.
c_dug
Changing the exhaust but leaving the carb as standard is whats likely to blow it up in the first place, i would at least advise changing for a bigger main jet, the exhaust manufacturer should be able to advise of or provide the correct size Thumbs Up
c_dug
adamcpi50sx08
PostPosted: 22:42 - 17 May 2009    Post subject: Reply with quote
i know that you have to rejet when getting a different pipe and im going to buy a box of jets with exhaust
c_dug
PostPosted: 23:17 - 17 May 2009    Post subject: Reply with quote
Cool, just checking Thumbs Up
c_dug
The last post was made 14 years, 346 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.9 - MySQL Queries: 16 - Page Size: 114.67 Kb
