Baffles
Pie-Roe
PostPosted: 23:05 - 17 May 2009    Post subject: Baffles Reply with quote
Hi there,
I've got over the inital awesomeness of having a bike that sets of car alarms on idle, and now wish to fit some baffles/quieting stuff.
I've got a drz, with a full fmf system. As far as I can make out, it was once road legal, and now is 'makes ears bleed' loud.
What sort of a baffle can I fit, I've found universal ones, that seem to require you to drill a hole in the lower to bolt it in. I'm not averse to this idea, I was just wondering if there was any other way.
Pyro
TUG
PostPosted: 00:41 - 18 May 2009    Post subject: Reply with quote
Urm dont think one could be fitted without drilling,and unless you can some how pack it with something which requires drilling out rivets an then packing it with wadding then re-reviting it i'd go with the simple bolt type? But i'm imagining its got a cone tip so thats why you dont want to drill it?
Haz ER-5, innit!
The Tot
PostPosted: 01:07 - 18 May 2009    Post subject: Reply with quote
I'm sure there's ones that are held in with an inner circlip which presses against the inside of the baffle and exhaust spout?
Failing that, red bull can + wire wool... lots of it. It's a good, temporary way of passing your MOT on a race can. well I did use a baffle which was next to useless in terms of noise suppression, hence the red-bull can and wire wool.
Never argue with autism
The last post was made 17 years, 116 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.3 - MySQL Queries: 14 - Page Size: 35.87 Kb
