One for you 2 stroke nuts
Bike Chat Forums Index -> Show & Tell Goto page 1, 2, 3, 4, 5, 6, 7, 8, 9, 10  Next
binge
Emo Kiddy
PostPosted: 23:55 - 22 May 2009    Post subject: One for you 2 stroke nuts Reply with quote
Had a little mishap with the new Lifan 150 engine. It's dropped a gear and I cant be arsed to split the cases just to replace the gearbox.
So, I had access to a TZR engine which was doing nothing. I've got access to a MIG and an OXY welder. So I thought why the fuck not.
Not got very far yet, Managed to get the engine fitted into the bike on a temp basis. Just to eye up what needs to go where.
Engine mount wise. The 2 back mounts can be made up from steel plates.
The front bottom mount wont be mounted to the frame as its an open pit bike frame, So I'll use these to mount my bash guard.
The top cylinder head mount I will weld a plate to the bottom of the frame, Drill/tap it, And secure it there.
Hard part is going to be getting an exhaust to fit.
Heres a few pics.
https://img.photobucket.com/albums/v358/binge/Photo0121.jpg
https://img.photobucket.com/albums/v358/binge/Photo0122.jpg
https://img.photobucket.com/albums/v358/binge/Photo0123.jpg
https://img.photobucket.com/albums/v358/binge/Photo0128.jpg
https://img.photobucket.com/albums/v358/binge/Photo0129.jpg
26bhp~ I believe. 6 speed gearbox. The engine is designed to drive an 18" rear wheel. So it should be a little weapon. Smile
Ben
PostPosted: 00:04 - 23 May 2009    Post subject: Reply with quote
That is more like it Mr. Green Drooling
SM.Morgan
PostPosted: 00:19 - 23 May 2009    Post subject: Reply with quote
Could have bet you'd be the first to post.
Looks like fun binge, keep us updated.
Harley XR1200
Whosthedaddy
PostPosted: 00:20 - 23 May 2009    Post subject: Reply with quote
Any reason as to why its always the TZR engine thats used in the pit / monkey bikes? I imagined it to be more of a tight fit under the frame but it looks right at home. Just need a side mounted rad like on a crosser and the exhaust to come the other maybe?
davthegreat
PostPosted: 00:35 - 23 May 2009    Post subject: Reply with quote
thats fat Cool
The Artist
PostPosted: 00:42 - 23 May 2009    Post subject: Reply with quote
Fantastic! Mr. Green
binge
Emo Kiddy
PostPosted: 07:22 - 23 May 2009    Post subject: Reply with quote
Not totally sure really. Gaz had the engine sat in his garden doing nothing. I completely rebuilt his Pit bike for him, So he gave me the engine and all the ancillaries to go with it.
Im quite lucky having a KLX 110 style Pit. Where the KX65 is liquid cooled, The front shrouds are designed to house a couple of radiators.
So theres plenty of room to stash one in there.
Not overly sure about the pipe. I've got a TZR pipe but the expansion chamber is just too big,
I dont mind loosing a few BHP through having a smaller expansion chamber. Might have a look into pipes for the smaller CC KTMs.
Something must fit. I can cut and re-weld the manifold to make it fit the engine. Its just getting the expansion chamber to sit on the bike without fouling the floor thats hard.
Ben
lllN30lll
PostPosted: 07:43 - 23 May 2009    Post subject: Reply with quote
now that's a proper engine to have in a pit bike.
Really looking forward to seeing it running and a top speed run Laughing
Turbo R1
CRF450R
Welshd1k
PostPosted: 08:43 - 23 May 2009    Post subject: Reply with quote
thats gonna be fucking lethal i want ago please
BenR
PostPosted: 10:03 - 23 May 2009    Post subject: Reply with quote
Where you going to put the rad? Will be mental when it's done. Twisted Evil
Gazdaman
I did a trackday!!!
PostPosted: 10:05 - 23 May 2009    Post subject: Reply with quote
Good work, I'll be watching this closely.
Gaz
PostPosted: 10:07 - 23 May 2009    Post subject: Reply with quote
Few people around who know what they are doing and could make you a custom expansion chamber.
PostPosted: 11:19 - 23 May 2009    Post subject: Reply with quote
The tuned length will be critical. I'd suggest trying to get someone to custom make an expansion chamber with the same volume and chamber dimensions as a TZR exhaust but curved around to fit the pit bike.
It is doable, my Two stroke tuning book explains how it is done, but you really really need to know what you are doing.
BenR
PostPosted: 12:17 - 23 May 2009    Post subject: Reply with quote
What about modifiying a scooter exhaust? Like a DNA/runner pipe?
ZBD
PostPosted: 13:24 - 23 May 2009    Post subject: Reply with quote
Do not know where you are based but this guy is great
https://www.higgspeed.com/
Alcohol is the answer, it's the question I forgot ....
PostPosted: 13:25 - 23 May 2009    Post subject: Reply with quote
A good idea, but it won't work. Scooter engines are tuned to make most power at the revs at which they are designed to work. The gearbox does the acceleration etc.
A bike engine works over a much greater rev range and so the expansion chamber will need to be longer, have a greater volume and probably not be such a harsh shape.
The only way to get good power out of this engine will be to get a TZR125 volume and gradient pipe made up, curved in the style of a motocross exhaust. It would probably be closer to modify a DT125 exhaust to fit.
In fact thats not a bad idea. Binge, look for a suitable DT125 exhaust! Smile
binge
Emo Kiddy
PostPosted: 17:13 - 23 May 2009    Post subject: Reply with quote
I'm pretty limited to space thats all.
I've still got to find a way to mount the carb! Its very close between the inlet port and the frame.
Might have to get a custom manifold which brings the carb out at an angle. Not too sure yet.
Might even have to get a different frame which isnt twin tube.
Ben
PostPosted: 22:39 - 23 May 2009    Post subject: Reply with quote
It still might work. A few people have done it on the Fizzy forum before.
binge
Emo Kiddy
PostPosted: 22:45 - 23 May 2009    Post subject: Reply with quote
I'm just very limited with space that's all.
I'd like it to run under body because I think it looks tech on the Supermoto bikes. BUT I wont be able to have the bike up on the stand to change the tyres.
Having it run over the top of the engine limits my space even more. I need to find a home for the carb yet.
Ben
binge
Emo Kiddy
PostPosted: 22:53 - 23 May 2009    Post subject: Reply with quote
Not sure what the score is with this.
It's a pipe made for the RM65. My bike is based on the KLX110 (which is basically an RM65 with a different engine).
So it will fit the bike how I want it to. I'm just worried about the diameter of the pipe work being too narrow.
https://i6.ebayimg.com/08/i/001/31/66/684e_1.JPG
MaybeGuy
PostPosted: 02:14 - 24 May 2009    Post subject: Reply with quote
what about a DTR exhaust? same engine etc.
when are you going to mount the engine properly?
binge
Emo Kiddy
PostPosted: 21:19 - 24 May 2009    Post subject: Reply with quote
Had another go at it in the garage tonight. I've made the bottom engine mounts, And fitted them up.
Just got to fab up some top engine mounts now.
I've offset the engine to the right by 33mm so the sprockets line up. So the mount on the cylinder head will need to be modified. Or I will need to weld a plate to the underside of the frame tube and have that offset by 33mm too.
I'm considering changing frames again. Back to a standard style "swan neck" frame, Rather than the Twin tube trellis frame. I need more room between engine and frame basically.
Looking into DT exhausts at the moment. I dont want to spend loads of money until I am sure it will fit and work.
Fitting the carb is my main concern.
Ben
400bandit
PostPosted: 23:16 - 24 May 2009    Post subject: Reply with quote
I doubt these will be of any use but what they hey
https://monkeybike.co.uk/acatalog/Carburettors_&_Manifolds.html
Cool project!
Joe
binge
Emo Kiddy
PostPosted: 23:35 - 24 May 2009    Post subject: Reply with quote
Not really. But I've been looking at pictures of DT125 engines. And the Inlet manifolds seem to be at a 45 degree angle on them.
So IF a DT125 inlet will fit the TZR125 engine, Then I'm laughing.
Ben
bykerbaz
PostPosted: 23:36 - 24 May 2009    Post subject: Reply with quote
the dtr inlet comes out on an angle and fits straight onto the tzr lump
its a different shape to the straight tzr one and should be just the job for you Very Happy
www.dtr125speedshop.co.uk
your one stop shop for dtr stock and performance parts!!!
The last post was made 17 years, 146 days ago. Instead of replying here, would creating a new thread be more useful?
Page 1 of 10
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.7 - MySQL Queries: 13 - Page Size: 132.02 Kb
