'99 R1 Gearbox Rebuild
Fortuna
PostPosted: 20:06 - 12 Jun 2009    Post subject: '99 R1 Gearbox Rebuild Reply with quote
Hi.
Early R1's suffer from the dogs wearing out extremely quickly which causes them to jump out of 2nd gear when under power. Not only does it jump out but it causes damage to other components as well.
I'm surprised mine hasn't gone earlier to be honest as it's done 20,000 miles and I used to go up to London on it regularly.
Here's the engine with the bottom case removed. You have to remove all cases,oil pump,clutch and sump.
This is the only way to remove the gearbox. The engine is worked on upside down. No gasket is used between the cases either!
https://www.spyderman.pwp.blueyonder.co.uk/images/BikePics/DSCF0050.JPG
https://www.spyderman.pwp.blueyonder.co.uk/images/BikePics/DSCF0051.JPG
Damage to the selector fork.
https://www.spyderman.pwp.blueyonder.co.uk/images/BikePics/DSCF0047.JPG
Damage to the guide in the selector drum.
https://www.spyderman.pwp.blueyonder.co.uk/images/BikePics/DSCF0048.JPG
Drive for 2nd comes from engaging with 6th. Here's the damage to the dogs on 6th. Notice the 45º chamfer on the left side of the dog.
https://www.spyderman.pwp.blueyonder.co.uk/images/BikePics/DSCF0054.JPG
https://www.spyderman.pwp.blueyonder.co.uk/images/BikePics/DSCF0055.JPG
https://www.spyderman.pwp.blueyonder.co.uk/images/BikePics/DSCF0053.JPG
And finally the damge to the engagement holes on 2nd.
https://www.spyderman.pwp.blueyonder.co.uk/images/BikePics/DSCF0052.JPG
One thing that was surprisingly easy was getting the engine out of the frame.
The new parts have 5 dogs as opposed to 3 and a slight undercut to prevent this happening again. I'll do a side by side when the new bits arrive.
Handsome
PostPosted: 20:16 - 12 Jun 2009    Post subject: Reply with quote
Therein lies the problem and answer, if it'd been a '98 R1 Chuck Norris would have been round and done it for you...
Fairplay though as for me to attempt something like that I'd have needed two weeks to think about it, another week to stand there looking at it scratching my arse, then when I attempted it, copius amounts of tea and cigarettes... Thumbs Up
Fortuna
PostPosted: 20:25 - 12 Jun 2009    Post subject: Reply with quote
My dad was supposed to help me but he had a Neil Buchanan so I really didn't have an option. Once you get stuck in it's ok.
I have had lots of tea and smokes though Smile.
Frost
PostPosted: 21:38 - 12 Jun 2009    Post subject: Reply with quote
Bloody hell that looks an arse to work on!
I'm not surprised litre bikes do that to the lower gears of bikes with the amount of power they have. Last time i bought some gears they were about £45 per cog, the selector fork shouldnt be quite so bad, but that barrel is going to be expensive me thinks. Problem is that a 2nd hand gearbox might be in just as bad condition. Confused
Cheaper than getting a new bike, or getting a mechanic to do it though i suppose. Once its done you will at least be safe in the knowlege that its not going to need doing again.
Fortuna
PostPosted: 22:03 - 12 Jun 2009    Post subject: Reply with quote
That is indeed the dilema I faced. There was a complete one on ebay that went for £150. I was in two minds for ages then decided that new items was best as the ebay one might be damaged. Even if it was fine I would probably have to buy new 2nd and 6th anyway as it probably had the old type that eventually slip.
New parts is at least peace of mind as well.
It would have cost me well over £1000 if I had taken it to a mechanic to do due to labour. Gears are £51 for 2nd and £60 for 6th.
Irezumi aka Reuben
Carrot Top
PostPosted: 22:11 - 12 Jun 2009    Post subject: Reply with quote
I assume you mean they don't have a paper based gasket. Youre aware they use a silicone sealant gasket?
400bandit
PostPosted: 23:57 - 12 Jun 2009    Post subject: Reply with quote
Yamabond I take it? Can't remeber the code for it but it's supposed to wicked stuff.
Joe
Fortuna
PostPosted: 00:22 - 13 Jun 2009    Post subject: Reply with quote
Joe
That's the one Smile
Quite a few people who watched me were surprised they don't have them. Was just for those who don't know.
There is a gap of 5 years, 312 days between these two posts...
sloppy2ndgear
PostPosted: 00:10 - 21 Apr 2015    Post subject: Re: '99 R1 Gearbox Rebuild Reply with quote
[quote="Fortuna"
The new parts have 5 dogs as opposed to 3 and a slight undercut to prevent this happening again. I'll do a side by side when the new bits arrive.[/quote]
Hi mate i hope you see this and reply because i am in need of your help. I just have one simple question that no1 can answer for me except you it seems lol. When you ordered the 5dog instead of 3dog gears, did you order the part number on the 5jj parts manual and the 5 dogs came instead of 3 dogs or was there a completely different part number that you used?
Will love you forever if you can remember!
Thanks in advance!
Iain.
PostPosted: 09:11 - 21 Apr 2015    Post subject: Reply with quote
Threads nearly six years old & he's not been on here since 08 Jan 2014... Confused
c_dug
PostPosted: 09:12 - 21 Apr 2015    Post subject: Reply with quote
Might be worth dropping him a PM, some people get an email notification when a PM arrives.
sloppy2ndgear
PostPosted: 11:40 - 21 Apr 2015    Post subject: Reply with quote
thats how desperate i am loooooooll
will pm him now did not think of that Embarassed
The last post was made 11 years, 153 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.48 - MySQL Queries: 13 - Page Size: 75.75 Kb
