Flat top pistons and flat cylinder heads - why?
bmwsport
PostPosted: 21:49 - 18 Jun 2009    Post subject: Flat top pistons and flat cylinder heads - why? Reply with quote
Anyone know how flat top pistons and flat cylinder heads improve performance? or if indeed they do?
Also does anyone run a single ring piston on the road? i understand you get less friction with a single ring but i presume they dont last very long and probably smoke more?
Cheers.
PostPosted: 13:06 - 19 Jun 2009    Post subject: Reply with quote
Flat piston and flat head? Where does the valve open-up into?
NSR Mick
PostPosted: 13:22 - 19 Jun 2009    Post subject: Reply with quote
You will only find single ring pistons on a 2 stroke where smoke isnt an issue.
PostPosted: 13:28 - 19 Jun 2009    Post subject: Reply with quote
A domed piston gives a lousy combustion chamber shape. A flat head with a combustion chamber in the piston is cheap to make (used on the old Morini V Twins and the Alfasud, for example).
Only one that I know that switched around is Cagiva with the various Mito engines. Some had flat topped pistons, others slightly domed. Think both work pretty well , but mixing the parts up is at best going to lose a lot of power (flat piston with head for domed piston).
bmwsport
PostPosted: 13:42 - 19 Jun 2009    Post subject: Reply with quote
Thanks guys, ok keith, yea i wasn't planning on mixing the two, will go for flat on both i think, vhm do a a nice flat cylinder head.
Any views on the single ring piston?
No valves on a two stroke Geri!
PostPosted: 13:45 - 19 Jun 2009    Post subject: Reply with quote
Single ring piston just exchanges a bit of life for a tiny bit of power. Not sure it is worthwhile on the road, although single ring pistons tend to be cheaper which partly compensates.
bmwsport
PostPosted: 13:59 - 19 Jun 2009    Post subject: Reply with quote
Cool thanks keith, i think its worthwhile in that case, the forged wiseco single ring is half the cost of the two ring one as as i dont mind doing a top end rebuild every 4-5k i think it would be worth it, my only concern would be that i'd rather it wasnt seriously smokey, but i cant see that they can be that different to a two ring providing the piston is the right size.
PostPosted: 14:01 - 19 Jun 2009    Post subject: Reply with quote
On a 2 stroke I don't think it will make the slightest difference to how smokey it is.
Believe that forged pistons are meant to have a different clearance to cast pistons so make sure you take account of that.
The last post was made 17 years, 11 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.9 - MySQL Queries: 14 - Page Size: 57.28 Kb
