CBR600F Intermittant Tacho
arry
PostPosted: 13:12 - 24 Jun 2009    Post subject: CBR600F Intermittant Tacho Reply with quote
Hi all
Wonder if someone can help.
Picked up an R Reg CBR600F last night and rode 120 miles home, which was lots of fun Laughing However, had a problem with the rev counter going intermittant - on the motorway it was working, then I looked down and it'd dropped to zero, then 5 mins later had rectified itself and was working again.
Whilst sitting at the services it dropped again - so I turned the bike off, restarted it and it started to work.
Any ideas?
Thanks Smile
Bofh5
PostPosted: 15:38 - 24 Jun 2009    Post subject: Reply with quote
will most likely be a loose / dry / dirty connector if its on off.
bit of a sh1t if its on the panel end as its fiddly as hell to get the off on mine.
(L)users...Disk space is to good for them.
Bikes: Honda 50 / CB125-TDC / 93 CBR600 F2 (Stolen & Trashed) / 2001 SP-1 (Sold) / 95 CBR600 F3
arry
PostPosted: 16:02 - 24 Jun 2009    Post subject: Reply with quote
Righty ho - sounds like I need to get me a Haynes manual and start pulling it to bits.
Is it an electric sender or some sort of cable drive?
Thanks for your help Thumbs Up
Bofh5
PostPosted: 16:10 - 24 Jun 2009    Post subject: Reply with quote
yep it will be a an electronic pulse type. quick look at my e-manual it just mentions the connectors and what the voltage should be.
i'll check my haynes when i get home should be more in depth.
arry
PostPosted: 16:13 - 24 Jun 2009    Post subject: Reply with quote
Thanks mate, that's really appreciated Thumbs Up
Timmeh
PostPosted: 18:31 - 24 Jun 2009    Post subject: Reply with quote
By far the biggest cause of CBR tacho wobble is the screws that hold it in place get rusted. They bolt straight through the back of the circuit board and eventually they stop conducting.
Whip the thing out, replace the screws if they are rusted and scrub up the contacts with a kitchen sponge and some vinegar until they are shiny.
arry
PostPosted: 06:22 - 25 Jun 2009    Post subject: Reply with quote
Star Thumbs Up Just need to find out how to remove it now then Very Happy
Timmeh
PostPosted: 14:24 - 25 Jun 2009    Post subject: Reply with quote
the clocks are an arse.
You'll have to remove the whole front, disconnect the wiring blocks, remove the mirrors and the plastic bits, then use a deep narrow 8mm socket to get to the three bolts holding it all in place.
It also might be easier to undo the bottom front subframe bolts and rotate the subframe down and away from the front to get access.
arry
PostPosted: 11:37 - 26 Jun 2009    Post subject: Reply with quote
Boo! I might just live with it for a while and see what happens lol
The last post was made 17 years, 119 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 60.28 Kb
