Squeeking Rear (shock, bush or swing-arm?) -Ideas??
Smooth
PostPosted: 22:18 - 01 Jul 2009    Post subject: Squeeking Rear (shock, bush or swing-arm?) -Ideas?? Reply with quote
The rear end of my TDM 850 has gained a loud squeek/creek under compression/de-compression.
Whilst both pushing down on the footpeg and allowing it to rebound, I can feel a vibration through the shock spring (It's a Hagon rear shock)
Slackening off the lower pivot bolt stopped the noise. I whipped out the bolt, gave it some grease and also smeared the swing-arm-mating faces of the shock pivot area.
The noise was still there when I re-fitted the bolt... Rolling Eyes
Is this likely to be a worn lower shock or shock bush? Do Hagon do spare parts or is it just part of a re-build?
Should there be washers/spacers/O-rings between the shock pivot and swing-arm?
Could it actually caused by dry swing-arm bearings rather than the shock?
TDM850
temeluchus
PostPosted: 15:16 - 02 Jul 2009    Post subject: Reply with quote
give hagon a ring, you should be able to buy the bushes seperately. Id get the shock out and give everything a good clean, and grease anythign that moves.
I had a similar squeek and it was one of the bushes, it had dried out.
The last post was made 17 years, 118 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.39 - MySQL Queries: 14 - Page Size: 31.95 Kb
