sv650 brake help
bagger
PostPosted: 19:52 - 30 Jun 2009    Post subject: sv650 brake help Reply with quote
on the way from work earlier while heavy braking there was several loud bangs and the brakes were on and of rapidly(at first i thought the disc had broke)but when i had a look around the diaphragm had been pulled/distorted into the reservoir?
i know the pads are low and need changing but does anyone know why this happened?
should i worry? i opened the resevoir and put it back correctly(it had basically turned inside out) the fluid level is fine Confused
cheer in advance
sv650s,cb350s
TUG
PostPosted: 21:33 - 30 Jun 2009    Post subject: Reply with quote
The diaphram inside the master cylinder fluid pot moves down to keep air gap to a minimum, as the piston moves more out as the pads become warn the level will drop to indicate pad wear or fluid loss.
The banging i'm unsure of, but i suggest you sort your brake pads out ASAP as tyre and brakes keep you safe.
Haz ER-5, innit!
The last post was made 17 years, 81 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.78 - MySQL Queries: 14 - Page Size: 31.36 Kb
