Softmod ANY Wii (Softmii 3.0)
Pedd
PostPosted: 15:08 - 27 Jun 2009    Post subject: Softmod ANY Wii (Softmii 3.0) Reply with quote
Softmii 3.0
Code:
Thanks go out to the entire wii scene, as without all of you this wouldn't exist.
Specific thanks for programs go out to waninkoko, wiigator, wiipower, crediar, comex, twiizers, and the rest of the coders that contributed code or programs to the scene and pack. Also a special thanks to Ckilla for all the screenshots used.
The Guide
This guide contains instructions to softmod any unmodded wii that is on system menu version 4.0 or below that works with bannerbomb or tp hack. If you are on 3.2 or 3.4 and want to be on 4.0 we suggest installing everything on your current system, then updating to 4.0 via wanins updater,then installing preloader again. Do to an uknown issue with CIOS introduced since usb loading was added disc channel loading does not work with these cios.
For disc channel loading you must currently use the original cioscorp (after softcorp if doing network install as this will patch all your ios with trucha again) and not be a LU64 user. Wanin has assured us rev14 will fix this issue for all. In the meantime we are looking into a workaround, using known good cios ,and will include all needed wads on site. Once the workaround is done you will have to find the stuff needed for offline install so grab it now!
https://softmii.org/section-blog/43-wiiguides/117-softmod40.html
Dont Click HERE
Current modes of transport = 125 superdream (in bits atm), 1978 GS750 chop, bandit 600(main one), 1982 bmw r100rs,
cx500 trike (hey its fun) oh and the car to ferry the missus and dogs around Smile
The last post was made 17 years, 118 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.57 - MySQL Queries: 13 - Page Size: 29.17 Kb
