| binge |
 binge Emo Kiddy
| Blue_SV650S |
 Blue_SV650S World Chat Champion
 Posted: 22:36 - 30 Jun 2009 Post subject: |
Piston port does NOT improve flow!!
Reeds are a better design as they are pressure operated and you can get longer inlet duration/porting.
Oh and finally he is pulling your p1sser, if you take the reed block out it won't run as it will blast a fair bit of charge back out the carb!!
Or was he suggesting other modifications not just take the reeds out?  ____________________ The purpose of life is to fight maturity. |
| MarJay |
 MarJay But it's British!
| Kickstart |
 Kickstart The Oracle
| bladerunner |
 bladerunner World Chat Champion
 Posted: 01:25 - 01 Jul 2009 Post subject: |
As said above the TZR is crank case induction and thus can not be converted to piston ported. Whoever said that I'm guessing don't know sweet FA about whats he/she is talking about as the piston wont be able to stop the mixture thats picked up fuel on the intake from blowing back out past the carb....picking up another dose of fuel...then being sucked back into the engine on the next stroke...picking up yet another dose of fuel!!! You get the idea!!! Reed valve motors are a lot more flexible in the mid range whilst having a good top end because you can have a lot longer duration on the porting without having to run into these problems.
Same with disk valve engines only to a lesser point. Also running less crank case volume by removing the reed block will only make this even more of an issue I would think!!!  ____________________ Current bikes...cbr929, KDX200's, Rd125lc mk2, RGV250's |
| hmmmnz |
 hmmmnz Super Spammer
The last post was made 17 years, 84 days ago. Instead of replying here, would creating a new thread be more useful? |
