| kingsknight |
 kingsknight World Chat Champion
| R6jonny |
 R6jonny Nearly there...
 Posted: 15:24 - 02 Jun 2009 Post subject: Re: Helpful Module 1 Links |
That is one of the most confusing things i have ever seen! I would never have managed that coupled with test nerves... ____________________ Honda NSR125 - Yamaha R6 - Ducati 748 - Suzuki GSXR750K6/GSXR1000K7/GSXR750K8 - Ducati 848 - Honda SP1 - Triumph Daytona 675
"simply because she is a female and is thus her actions largely make no sense whatsoever by default" |
| ThoughtContro... |
 ThoughtContro... World Chat Champion
 Posted: 16:35 - 02 Jun 2009 Post subject: |
Their layout diagram is more confusing IMHO, if you compare it to the manoeuvre diagram anyway.
You don't do it all in one go anyway. It runs something like this:
1. He'll tell you to treat the course like its a road, so do appropriate observations. You then get told to park in either of the green boxes to your left (2) or right (1). The green cones marking the parking space are 2.5m apart.
2. He'll tell you to take the bike off the stand in whatever box you parked it in and wheel it backwards into the other cones without hitting them, so the bike now faces forwards towards the slalom. I was told by an observing instructor that if you parked the bike originally in the leftmost of the parking spaces (2) you'll be wheeling the bike with it on your right, so if you find this odd park in the right hand space (1) to avoid this.
3 and 4. You'll get told to ride the slalom around the yellow cones (3) and do two figure 8 circuits of the blue cones (4). He'll signal when you've completed the two figure 8s.
The yellow slalom cones are 4.5m apart.
The blue figure 8 cones are 6.5m apart.
I did my shoulder checks before starting off.
5, 6 and 7. You'll get told to ride around the circuit (5) and head towards the speed trap where you'll do the avoidance manuoeuvre (6).
Your speed is checked as you pass through the red and yellow cones on each side. The minimum is 50 kph (31.1 mph). You swerve around between the two blue cones (6), the nearest which is offset from your path by 0.3m, and do a controlled stop with your front wheel inside the four blue cones (7). The four cones are spaced 1 x 1.5m apart and are 31m away from the swerve manouvre.
If you weren't fast enough you'll get a second attempt at the swerve.
Don't forget your checks before starting the 5, 6, 7 bit.
8. You'll next be asked to move to the yellow line marked by the three green cones. Here you'll do your checks and do a U turn (8), like you'd do on the road. The opposite kerb is 7.5m away, marked by another yellow line and three yellow cones.
9. You next get told to do the slow ride starting between two pairs of green cones (9), placed 17m apart. The examiner will walk in front of you with a clipboard. You stay behind him moving at walking pace, without putting a foot down. I was told by an instructor that the minimum time for the slow ride is 10 seconds, thats about 6.1 kph or 3.8 mph.
10 and 11. You get told to go round the circuit again (10) and come back through the speed trap at 50+kph as before, except this time the examiner will hold his hand up for you to do an 'emergency' controlled stop, after you've gone through the gates.
Remember its a controlled stop, breaking distance in the dry at 30 mph is 45 feet, Overall stopping distance 75 feet, so don't slam on the anchors and just cover the back brake.
Again if you weren't fast enough through the gate, you get a second attempt.
Don't forget your observations before starting 10 and 11.
It's not hard or confusing. It might first look like a sea of cones when you approach the course, but it's all separated out to make it easy enough. |
| dizzyybr |
 dizzyybr L Plate Warrior
| crazyjoyce |
 crazyjoyce Nitrous Nuisance
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
| tutton |
 tutton World Chat Champion
| ThoughtContro... |
| crazyjoyce |
The last post was made 17 years, 65 days ago. Instead of replying here, would creating a new thread be more useful? |
