Wiring help needed for a chinese pocket bike
VR250
PostPosted: 09:19 - 13 Jul 2009    Post subject: Wiring help needed for a chinese pocket bike Reply with quote
I have recently been given a pull start 2 stroke 49cc Chinese pocket bike (brand unknown).
Whilst I have reasonable mechanical skills with motorcycle engines, my electrical skills are pathetic. Sick
This bike was given to me with most of the wiring removed, whilst I have most the wiring, I have no intention of using it all.
I have removed battery, all lights, speedo, tacho,key etc.
I wish to use just a basic wiring setup (with killswitch) to run and stop the bike without the use of a battery.
Can anyone offer some advice as to what would need to be wired to what?
What it appears to have at the moment is a red wire coming from a generator? plate on rhs of crank. A black and a black with white trace from the crank reading coil(to kill button I assume). 3 wires coming from a aluminium box under the tank(voltage regulator i think), 1 red, 1 black and 1 grey.
Can anyone shed some light on this subject for me?
spitfire123
PostPosted: 10:10 - 13 Jul 2009    Post subject: Re: Wiring help needed for a chinese pocket bike Reply with quote
What it appears to have at the moment is a red wire coming from a generator? plate on rhs of crank. A black and a black with white trace from the crank reading coil(to kill button I assume). 3 wires coming from what (I think) to be a cdi under the tank, 1 red one black and one grey.
on the crap minis whithoutout no lights,battery or anything....there is just 1 wite comming out of the coil (black) that in tern connects to the kill switch.
that is all....and ofcore you have the ht going to your plug.
hope this helps!
You won't be able to eat my dust......As it'll settle before you get there.
VR250
PostPosted: 14:20 - 26 Jul 2009    Post subject: Reply with quote
Thanks for your help Smile Wink
baldy
PostPosted: 18:04 - 26 Jul 2009    Post subject: Reply with quote
If you are not using a battery you should get rid of the regulator. There will be a wire coming from near the flywheel with a tracer on it that goes to the coil. One from the coil to the cut out. The rest are irrelevant. I would completely remove the charging and lighting system as it's just dead weight.
The last post was made 16 years, 244 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.93 - MySQL Queries: 14 - Page Size: 40.54 Kb
