Piaggio Zip
MalossiX
PostPosted: 19:42 - 12 Jul 2009    Post subject: Piaggio Zip Reply with quote
Does it ever F**cking end?!?!?!
Posted on here in May for some help when my zip suddenly stopped & wouldnt start again.Finally,After 2 months & £600 worth of repairs,I collected it thursday.The Speedo wasn't working for a few miles...(but is now).Now,One of the rear indicators is flashing really fast.Not a major problem but all the same I'd like it sorted.
Anyone have an ideas?
PostPosted: 21:07 - 12 Jul 2009    Post subject: Reply with quote
Check your front indicator bulb of the same side Thumbs Up
MalossiX
PostPosted: 21:15 - 12 Jul 2009    Post subject: Reply with quote
Ok,I'll check that.When the front panel was off the same-side front indicator wire was loose even when connected.Maybe a bit of blu-tac or chewing gum will do the trick.
MalossiX
PostPosted: 22:09 - 12 Jul 2009    Post subject: Reply with quote
Just checked & the front side bulb isnt working.could be the loose connection or might need a new one.
PostPosted: 22:59 - 12 Jul 2009    Post subject: Reply with quote
You've sourced your problem. If it's easier to check the bulb, do that first but as you have said that the connection was a bit loose, it does point the finger at that being the fault.
If it is just a spade connector that is loose, you should be able to close it up with some pliers so it grips again.
The last post was made 17 years, 76 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.23 - MySQL Queries: 14 - Page Size: 42.49 Kb
