 jim-cr 250 Nitrous Nuisance
 Posted: 09:52 - 19 Jul 2009 Post subject: supermoto running power |
Hi all, just a quick question, im currently building a cr with a crm engine in, and its getting ready to be put on the road and in for its mot, just wanting to put a horn on it, however i have found a few live feeds with the bike running and they are only showing 2.65 volts, with the multimetre ( however this mulitimetre has been playing up and may be faulty), but even when revved up and wired up to the horn, it only makes the horn vibrate and not even produce any noise, unless you put your ear right up against it, (the horn is brand new 12v one, ive tried testing it on a good battery and its fine, so that should rule out the horn and any adjustment).
So i was just wondering how you get your horn to work with no battery, just the magneto, which is just the standered crm one.I would of thought it would produce enough power to make the horn work? been looking around and ive seen you can buy 6volt ones, do you think this is what i would need?
Any help would be super
Many Thanks
Jim |
 Ariel Badger Super Spammer
 Posted: 11:25 - 19 Jul 2009 Post subject: |
 Posted: 16:17 - 19 Jul 2009 Post subject: |
Thanks for the help, i asked the local mot guy the other day and he said it needs to be a proper wired up horn, so guess im just going to have to try and sort out the wiring issues, tried a different rec, but think it could be the stator at fault.
Thanks again
Jim |
 G The Voice of Reason
 Posted: 20:44 - 19 Jul 2009 Post subject: |
| jim-cr 250 wrote: |
Thanks again
Jim |
Post 1973 the horn should make a continual single note. How it does that is absolutly nothing to do with the MOT man. ____________________ Bikers make great organ donors, get 115 on your licence today. |
