| Gti |
 Gti Bendy Groupie
| cagiva gezzer |
 cagiva gezzer World Chat Champion
| yen_powell |
 yen_powell World Chat Champion
| Bendy |
 Bendy Mrs Sensible
| cal91 |
 cal91 Nearly there...
| Gti |
 Gti Bendy Groupie
| yen_powell |
| cal91 |
| Gti |
 Gti Bendy Groupie
| Phoenix |
 Phoenix Twisted Firestarter
| Mrs Kickstart |
 Mrs Kickstart Brolly Dolly
| Gti |
 Gti Bendy Groupie
| Al |
 Al World Chat Champion
 Posted: 19:43 - 19 Aug 2009 Post subject: |
Like Mrs Kickstart said, often combi boilers have a pump overrun feature which will dumb excess heat from heating the hot water into the heating circuit. Although the rad should only get warm for a short while after the hot water has been used.
The pressure shooting up and steam? (do you mean the steam came from the discharge pipe, rather then the boiler itself?)
Did you have to top up the pressure afterwards?
Sounds like the bladder in the expansion vessel (normally red and in the boiler casing) could be split or need re-pressurising.
The vessel has a rubber bladder which is filled with air at about 0.75-1.0bar and as the water heats up it takes the expansion. without it the pressure will just rise as it has nowhere to go until the pressure relif valve goes off.
You can check the expansion vessel is set to the right pressure by dropping the pressure of the system to zero and connecting a foot pump to the valve on the top of the vessel.
But It may just be easier to get somebody out to look at it, as I'm only guessing and thats all anybody else can really do without looking at it. ____________________ Yamaha FZR400RR 3tj
My Instagram Thingy |
The last post was made 17 years, 71 days ago. Instead of replying here, would creating a new thread be more useful? |
