Dismantling forks on YBR 125
66andrew99
PostPosted: 20:24 - 25 Jul 2009    Post subject: Dismantling forks on YBR 125 Reply with quote
Please excuse my vernacular or lack of technical wording, a little new to the repair and maintenance side of things.
Trying to change fork seals on my YBR, have loosened top bolt (at yoke) loosened bottom bolt (at axle) removed top bolt, drained oil and remove spring and spacer, but now I just cant get the bottom bolt to release the piston rod. It just rotates (stiffly) forever.
Would really appreciate any insight from my more technically experienced peers.
Thanks all
PostPosted: 22:33 - 25 Jul 2009    Post subject: Reply with quote
A length of dowling helped me do mine. Used some mole-grips to hold the dowl whilst undoing the bottom allen bolt. My forks are a similar design to yours so it may work for you.
Pat
PostPosted: 23:39 - 25 Jul 2009    Post subject: Reply with quote
3 minute instructional video.
https://www.youtube.com/watch?v=XhLo3V-sXKE
66andrew99
PostPosted: 20:14 - 27 Jul 2009    Post subject: Reply with quote
Sorted, cheers guys. Another question. Trying to source some new seals, ones I removed were 40 x 30 x 10, closest I can find is 40.5 x 30 x 10. Is it possible these will fit? Seems unlikely as 5mm might not seem like a lot but I'm sure it'll be a hell of a difference when I'm trying to get them in.
Otherwise does anyone know of a good mail order firm to get some decent seals?
Thanks all.
BadDog
PostPosted: 20:55 - 27 Jul 2009    Post subject: Reply with quote
Isn't it 0.5 mm that they're out by?
VFR400 NC30 > Kawasaki ZX6R > YAMAHA YZF-R1 > Moto Morini Corsaro Veloce
PostPosted: 23:22 - 27 Jul 2009    Post subject: Reply with quote
Can't help you with the fork seals (maybe different models have different diameter tubes[shrug] )
But i've got an owner manual in pdf if you want? (not a workshop manual)
Pat
The last post was made 16 years, 318 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.14 - MySQL Queries: 13 - Page Size: 48.85 Kb
