Shotguns...
map
Mr Calendar
PostPosted: 13:26 - 03 Aug 2009    Post subject: Shotguns... Reply with quote
Did a 'have a go' clay shooting session the other weekend and quite enjoyed it.
Obviously they were using light loads as didn't want to put people off with too much recoil.
So wondered if anyone had any advice on getting started.
What I've done so far...
Do a little research on various sites.
I've already been to the local shooting ground and will arrange a training session.
Need to tidy the house and get a gun cabinet then apply for the shotgun licence.
That maybe an issue as missus doesn't want an ugly steel cabinet (allow £150 ballpark) but will accept those disguised as furniture (so that's in the £1500 ballpark Shocked ).
I've already been told the horror stories of gun dealers sizing you up for a gun just to shift it off their shelves when it's not really suitable. I guess that's just similar to car and some motorcycle dealer shifting dodgy stock (someone say DK at the back Confused Wink)
As I understand it a 'reputable' dealer should let you try before you buy under the 72 hour rule.
What I'm asking...
Arrow Any general advice on starting clay shooting
Arrow Recommend a good gun to start with (and maybe keep with)
Arrow Any recommendations where to get stuff
Arrow Advice on taking a gun, ammo, etc. on the bike if and when required
Arrow What does actually happen when the Firearms Officer calls round?
I've already checked it is legal to carry on a bike so long as in a gun slip or broken in a case and can't be fired but was wondering about the actual practicalities.
Also I know the startup cost can be high (as with most hobbies) but is it affordable after that? Looking at the prices I'm allowing around £500 ballpark for the gun (or guns if the missus wants to start, either new of 2nd hand) and about £125/1000 shells after that.
Local club charges about £25 per 100 clays.
Thanks in anticipation Thumbs Up
Chriss
PostPosted: 13:49 - 03 Aug 2009    Post subject: Reply with quote
No real help, but I do know that the armoury on base here will allow you to keep fire arms there, so it might help bring down the start up costs a bit, at least til you can afford that antique gun cabinet. Might be worth asking your local armed forces base?
Other than that, why anyone wants to handle a gun is beyond me.
TheShaggyDA: I've got 3 or 4 pairs that predate my wife, so at least 11.5 years old.
map
Mr Calendar
PostPosted: 14:13 - 03 Aug 2009    Post subject: Reply with quote
Chriss wrote:
...why anyone wants to handle a gun is beyond me.
It's a bit like asking why anyone would want to handle a golf club, tennis racket, cricket bat, rugby ball, fishing rod, etc. etc.
As far as I can see it's just another hobby, like owning and riding a bike is to some people then spending money fettling it, cleaning it and making performance improvements.
Very Happy Thumbs Up
SlimRick
PostPosted: 14:41 - 03 Aug 2009    Post subject: Reply with quote
When I had a visit re. the license, they just came round and checked the gun cabinet - mine's bolted to the floor in our understairs cupboard. Had a quick chat and that was that.
I started off and stuck with one of these from Lanber:
https://www.a2kda.com/pics/kit/2097.jpg
Not an amazing gun, but does the job nicely and not stupidly priced.
Chriss
PostPosted: 16:57 - 03 Aug 2009    Post subject: Reply with quote
map wrote:
Some very true points
I guess for most professional motorbike riders, the last thing they want to do on their time off is more of the same. Laughing
I'll stick to assult rifles and pistols, and detest every time I have to handle it.
Everyone needs a hobby though! Thumbs Up
karoshi
PostPosted: 17:02 - 03 Aug 2009    Post subject: Reply with quote
from what i remember from years back the police visit was just to check that you have a suitable cabinet in a suitable position.. i.e. proper steel cabinet bolted to a solid wall
at my parent's place my father has a seperate locking safe in the garage that he uses for shotgun cartridges and the bolt actions for his rifles.. this went over fairly well with the inspector
always wear ear protection for shooting clays, the damage can start to build up pretty quickly.. the little stick-in earbuds are fine, decent defenders with a head-strap are better provided theydont' get in the way of the gun-stock.
in terms of sizing up a gun, a quick way to see if something should be about right is to hold the trigger handgrip part as you normally would, with your trigger finger extended to rest on the trigger guard.. the guard edge should be at or further away than the first joint in your index finger..
..with it held in your trigger hand, bend your arm 90degrees at the elbow and try to rest the butt into the inside of your elbow joint, if it doesn't rest up against the inside of the top part of your arm (elbow end of the bicep) chances are the stock is too short for you.
If you've got big / thick fingers try to steer away from double-barrel guns with two triggers, the ones with an auto-selecting single trigger are easier to move your trigger finger around, the downside being you're locked into shooting one barrel before the other
with double-barrels for clays, you can play with the choke settings also, my last gun was set up with 3/4choke on the lower, full choke on the upper.. the higher the choke amount the closer together your shot pattern will be at a set distance, on clays this translates into higher chokes getting 'kills' from a longer range but you have to be more accurate.
try moving about with the gun in the shop for a bit, check it for weight balance, if it's very nose heavy you'll get tired quickly hoiking it around for 60-100 clays.
no idea about the legality of taking a gun on a bike.. most slip covers hold the gun in a single piece which would be far too long.. maybe if you break one down it'd go in the sa80 case on an mt500? Smile
Well, I've wrestled with reality for 35 years, Doctor, and I'm happy to state I finally won out over it. - Elwood P. Dowd
ZRX61
Victor Meldrew
PostPosted: 17:30 - 03 Aug 2009    Post subject: Reply with quote
I just use my 9shot pumpaction Mossberg 590 for clays. Nothing pisses off the Ruperts with their $3500+ clay guns more than some oik with a $300 riot gun hitting the clays while shooting from the hip. Wink
smegbrains
PostPosted: 21:24 - 03 Aug 2009    Post subject: Reply with quote
https://www.youtube.com/watch?v=mu965sVymMs
Turn up with one of those.
On a serious note, speak to people at the shooting range where you went. They will give you great advice and a lot of it will be local too as Firearms Inspectors get well known Smile
Current Bike: Honda CBR 600F
Ex Bikes: Suzuki GX 125
Johnny GSX-R
PostPosted: 23:57 - 03 Aug 2009    Post subject: Reply with quote
MAP
If you get ya permit sorted i have 2 for sale CHEAP
Got a 3 shot 12 bore 'MAGTECH' pump action and
a 'SPANISH' 12 bore side by side.
Both fixed choke, Magtech has only had 100 through it, Spanish has newly french polished woodwork and blued barrels.
£250 for the pair.
Robby
Dirty Old Man
PostPosted: 10:15 - 04 Aug 2009    Post subject: Reply with quote
You can get started shooting clays very cheaply.
The ugly steel cabinets are good, hide it behind a curtain is the woman is being difficult, or just push her down the stairs. The cabinet should be well out of view of windows, so an alcove in an upstairs room is ideal.
When I had mine inspected the firearms officer just gave it a few good tugs to see if he could pull it off the wall. Don't fit it with rawl plugs, we used some long wood screws to screw mine into fresh putty in the brickwork I think. Set good and solid.
The inspector will ask what you're going to use it for (shooting women, children and coppers, obviously), and he'll probably ask if you belong to a club or have friends that shoot. You don't need to belong to a club for a shotgun licence, but it's worth it. You won't find out about cheap shoots any other way.
I think I paid about £40 for my old shotgun, with a couple of boxes of cartridges. It was a nasty cheap old side by side, farmer gun, but it did the job. Much like riding a bike, there's no point buying something nice until you learn how to shoot. Learning with something shit will make you a better shot, you have to work at it more.
It's not worth going for pump action or semi auto over here - I think you're only allowed legally to load 3 cartridges, and when shooting clays they'll only let you load two, same as the double barrelled boys. Go for 12 gauge.
Grendel
PostPosted: 18:18 - 04 Aug 2009    Post subject: Reply with quote
I wandered about trying Clay shooting since theres a fair few clubs in Hampshire but i wandered if i would be allowed to use a combat shotgun like any of these:
https://www.rusmilitary.com/html/firearms_saiga12.htm
https://www.rusmilitary.com/html/firearms_saiga410.htm
https://www.rusmilitary.com/html/firearms_safir410.htm
Or would it be seen as unsporting and find not many clubs would except me with such a gun?
Or would it just be cheaper to buy a 2nd sporting shotgun?
Past bike: 2004 Hyosung Comet
Current bike: 1993 Honda Transalp
Transalp Page: https://www.facebook.com/home.php?ref=home#!/group.php?gid=11418462079
tatters
Exxon Valdez
PostPosted: 00:18 - 05 Aug 2009    Post subject: Reply with quote
There are military firearms and are Section 5 "Prohibited Weapons"
ZRX61
Victor Meldrew
PostPosted: 05:34 - 05 Aug 2009    Post subject: Reply with quote
Seems odd then that are designed specifically for the UK market.... Rolling Eyes
Grendel
PostPosted: 06:00 - 05 Aug 2009    Post subject: Reply with quote
Thats what i was thinking? Thinking
Mind you at thouse prices i expect you could probably pick up a nice 2nd hand sporting gun?
map
Mr Calendar
PostPosted: 10:42 - 05 Aug 2009    Post subject: Reply with quote
As I've been reading up on this for a shotgun certificate in the UK the barrel length has to be a minimum of 24" and capable of holding no more than 3 cartridges.
Any more cartridges and it comes under a full firearms certificate.
So that means only this one, Saiga-12 with a 2 capacity magazine is the only one legally for a shotgun certificate.
However, as said in the advert, 'PLS NOTE: THIS PRODUCT REQUIRES FIREARMS LICENSE !'.
However, as said, at those prices what I've been looking at something like a secondhand Lanber already mentioned fits the bill.
Mind you, as this is a bike forum, some interesting Ural combinations and bikes on that site.
P.S. Johnny GSX-R - you have PM!
Grendel
PostPosted: 16:43 - 05 Aug 2009    Post subject: Reply with quote
Thanks for that MAP
As for the Ural bikes i nearly bough the Ural Solo Classic:
https://www.mcasta.ru/eng/motorcycle/imz-solo2.html
But they ended up not bringing it into production. Rolling Eyes
dgo1212
PostPosted: 01:25 - 08 Aug 2009    Post subject: Re: Shotguns... Reply with quote
Don't know for sure but i think you also need another cabinet for your ammo as they can't be stored with the gun,and you're pretty limited to where the cabinets can go as if they're mounted to a wall it has to be an external one,could be wrong just going by what my uncle told me when i asked about his however his is a full firearms licence and may be stricter
Johnny GSX-R
PostPosted: 00:00 - 09 Aug 2009    Post subject: Reply with quote
[quote="robby"]
It's not worth going for pump action or semi auto over here - I think you're only allowed legally to load 3 cartridges, and when shooting clays they'll only let you load two, same as the double barrelled boys. Go for 12 gauge.[/quote]
AND????
You can put just 2 in the pump action.... How can ya say its a waste of time when i shot clays for years with my old 'Stevens Savage Arms' 3 shot pump ??
I used to shoot at a private ground and could / often did shoot with 3 shots / 3 clays.
My gun is a former 5 shot USA spec downrated to 3 shots with a tube to prevent the extra 2 being utilised.
Robby
Dirty Old Man
PostPosted: 22:19 - 09 Aug 2009    Post subject: Reply with quote
This is why I hesitated before writing that. I knew someone be along willy waving about a pump action or semi auto.
Two reasons.
First off, the only people I've known with pump actions or semi autos have been wannabe soldiers playing Mad Max.
The second is a practical problem. A beginner wants to just pan across and pull the trigger(s). Having to pump halfway through interrupts your aim, and won't teach you to be smooth.
I've never gone in for trying to be cool or fashionable when shooting. I keep it cheap, simple, and smooth. The only thing I get anal about it is a smooth, sharp, clean action on a rifle, firing a left hander with a shit action is horrible.
Your point about shooting three clays is valid, but a beginner isn't going to shoot three in a row. Nor are the rest of the people on the shoot, with their double barrels.
karoshi
PostPosted: 23:15 - 09 Aug 2009    Post subject: Reply with quote
My experience is mostly over 10 years old as i let my licence lapse when i moved to birmingham but..
I had a loan of a semi-auto 12gauge once for a clay shooting morning, shot 3 round of 20 clays (dismal hit rate as per my usual Smile ) but there is a benefit to them even in the UK
Yes you're legally limited to a 3 shot magazine meaning you still have to reload between each set of two, and I found it took longer to reload a semi than a standard break-action.. but the big difference was that because of the recoil ejector system, they have 20% of the kickback on each shot.. if you're a fragile type, or shooting a long day, a semi-auto is a lot kinder to the shoulder
*grins* I also had the issue that because i shoot left-handed, the semi's ejector system kept spitting the emptys at my face Smile
heh, my father has a 3shot savage still, I remember it for being great fun to play with, and for being really loose and clattery (to the point that my father had it serviced twice in succession because we thought something was wrong) but never breaking.. I also remember it getting some incredibly down-the-nose looks when I used it as the walking line gun on a pheasant shoot Very Happy
I'd agree with Robby though, for learning to shoot, a standard double-barrel would be much better/easier to get on with, by preference an over-under as they tend to have shorter barrels, better air venting between the two and also cheaper than side-by-side.
ZRX61
Victor Meldrew
PostPosted: 02:50 - 10 Aug 2009    Post subject: Reply with quote
Maybe you should stop hanging around with wankers...? Pumps are better HD guns... unless you think 2 or 3 people breaking into your house are going to wait while you reload to shoot the 3rd perp? Rolling Eyes
Oh thats right, I forgot you're not allowed to defend yourself or property in the UK. Get a pointy stick..... & put a cork on the end.
zephyrgirl
PostPosted: 07:04 - 10 Aug 2009    Post subject: Reply with quote
Surely, the only thing we should be discussing is reload speed.
If we're working on the approximate zombie staggering speed of 3ft/sec then you will need a gun you can reload at least 3 times/min to keep on top of a pack of 20.
Obviously you'll be taking out 3 or more with each shot as they are pretty fragile with their rotting flesh and all.
Die, Zombies, Die!
Fly away on my Zephyr?
I bloody wish.
karoshi
PostPosted: 12:54 - 10 Aug 2009    Post subject: Reply with quote
hmm, it'd depend heavily on the area, space and situation I think.
If I had a vantage point and decent range on the shambling zombie horde then a pump-acton with a full US 12shot magazine and a 3/4 choke barrel
If it was closer range but I had a 2nd person to work as my reloader i'd go for a pair of over and under 12gauges with 28inch barrels on full choke, should give a fairly tight spread up to what.. 30 yards? I'd want ones that have break-action automatic ejectors to speed up the process.. the reloader should be able to load one gun while i'm using the two shots on the other..
If it's close range / confined quarters and I'm on my own then I would probably go for a the same over-and under as above but sawn down to the end of the front guard and cut down to a pistol grip, I should be able to work the break action and safety one-handed, auto-ejectors to clear the spent shells while my left hand is grabbing shells off a table to reload.. may need a wrist strap though..
what? everyone has a Zombie attack survival plan don't they? Very Happy
D O G
PostPosted: 14:11 - 10 Aug 2009    Post subject: Reply with quote
Have you ever needed to do this?
pickled
PostPosted: 14:27 - 10 Aug 2009    Post subject: Reply with quote
buy the cheaper cabinate and put it in a wardrobe or cupboard and bolt the whole lot to the wall?
The last post was made 16 years, 331 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.21 Sec - Server Load: 1.87 - MySQL Queries: 13 - Page Size: 145.99 Kb
