| spitfire123 |
 spitfire123 Could Be A Chat Bot
 Posted: 12:51 - 04 Aug 2009 Post subject: mito new engine- refuses to start, backfireing etc....flames |
hi all,
for the part couple of months ive been rebuiliding my mito engine..
therse are the aprts ive done
Barrol
piston
rings
big end bearing
btoom end with crank
crank baalanced and trued
new main crank bearings
now i put in it to the bike 2 days ago and yesterday i had a friend come over to help me out to get it running etc..
well we put everything on (apart from fairings of corse) and all it does is relentlessly turn over and keepts shooting flames from the exhaust and backfire alot! and slowly spew blue 2st out of the exhaust...
now on assemblyi s used quite abiit of 2st oil to assemble all the parts wet....i fear ive used to much we tried throwing petrol in to the top of the head.....nothing but a huge backfire
now weve checked the spark and that is perfect and very bright (running the iridium plug) and there seems to be gettting fueel to the engine as there is a faint smell on the plug (but mostly 2st oil).
now another thing is when we take the plug out after cranking a while 99% of the time there is blue smoke comming out of the plug hole.
the engine only fires once ina while but there is more exhaust activity than engine activity.
any ideas before i get on with it today? as i realy want this working by tommrow as i have an MOT thurs
thanks all  ____________________ You won't be able to eat my dust......As it'll settle before you get there. |
| The Artist |
 The Artist Super Spammer
| spitfire123 |
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 19:03 - 04 Aug 2009 Post subject: |
just keep going. it'll fire more often as the oil is got rid of.
the stator plate is fixed, you cant adjust it without modifying the holes. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| ms51ves3 |
 ms51ves3 Super Spammer
| TUG |
 TUG World Chat Champion
| spitfire123 |
| spitfire123 |
| spitfire123 |
| yuri2085 |
 yuri2085 World Chat Champion
| spitfire123 |
| spitfire123 |
 Posted: 14:50 - 05 Aug 2009 Post subject: |
update:
took the plug out...put another teaspoon of fuel in and i had 1 big backfire.....
i then removed the plug and there was a faint smoke comming out of the hole which i now no top be 2st oil as it was all over the cdi box....so i cranked it constanly for 3 mins untill the smoke was gone(from the plug hole)....i then put the plug back n and stuck the choke on and turn it over a few more times....nothing what so ever?
now all the oils got to be cleared hasnt it?
what could it be?
there is a strong spark very good comp etc...but no running!
anyone?
chars  ____________________ You won't be able to eat my dust......As it'll settle before you get there. |
| spitfire123 |
 Posted: 17:43 - 05 Aug 2009 Post subject: |
last update of today:
right soent about 1.5 hours down the workshop...and i took off the flywheel etc..and tried re-possitioning the magnito to the most central it would go (litral 2mm differance) i then checked the spark (still very stong) i then tried to start it...and it still wont run
there is clearly petrol on the spark plug and a strong smell in the bore but no action
now it has:
fuel
compression
spark
why the hell dosent she want to go!
ive never had ANYTHING like this before!
and to top it off my syatror bendix has Fvucked from the relentless cranking, and will only turn over in very short bursts
any help much apriciated  ____________________ You won't be able to eat my dust......As it'll settle before you get there. |
| BenR |
 BenR World Chat Champion
| spitfire123 |
| Kickstart |
 Kickstart The Oracle
| spitfire123 |
| Kickstart |
| spitfire123 |
| tshort2007 |
 tshort2007 Scooby Slapper
| spitfire123 |
 Posted: 12:23 - 08 Aug 2009 Post subject: |
hi all,
got it sorted...
MY fault enterily.
turns out i put the pickup 25% out of posstion , i was sitting there for ages glaring at it an dit came to me ad the pickup wires dident look like they were routed propely.
anyway..now starts 1st time on the button...and ive set the balancer shaft up...but its still a bit vibratish even with it setup?
could it be im going to hhave to take my flywheel off again and try diferent firing points?
thanks  ____________________ You won't be able to eat my dust......As it'll settle before you get there. |
| tshort2007 |
 Posted: 12:30 - 08 Aug 2009 Post subject: |
BIG SLAPS ALL ROUND
Glad you got it sorted. If you have vibration, its an indicatin of something not balanced. if the ballencer shafts are set up properly, then it may well be crank, flwheel, clutch, basically anything that rotates!
I have it on my AR, cant be arsed to sort it, and it gives a good arse massage when flying along at 80  |
| spitfire123 |
The last post was made 16 years, 310 days ago. Instead of replying here, would creating a new thread be more useful? |
