2 stroke engine power
The Artist
PostPosted: 15:31 - 15 Aug 2009    Post subject: 2 stroke engine power Reply with quote
Not bike related so in RB
I am on holiday, got a small boat with a 30hp yamaha 2 stroke engine. 2cyl and from early 90's I think.
Basically, last year we used it, it did a reasonable 12-15 knots and about 20 with only 2 people on a calm day.
Now this year, it is a lot slower. We had 7 people in and it wold barely do about 5 knots. With 2 people in it only does around 10.
It has had a new plugs, fresh fuel, it pumps cooling water fine and starting it is easy. After the entire winter spent outside not under cover, it started 3rd pull.
How do I get it back up to power. I have tried cleaning the carb, it was spotless anyway. All controls work fine.
I would like to know the proper way to set ignition timing advance on it. Anyone know anything about outboards that can help?
Dischord
PostPosted: 15:42 - 15 Aug 2009    Post subject: Reply with quote
Is it pre-mix or does it have an oil pump? any blue smoke? Could just be that it can't cope with carrying 7 people. Or if it's a really tired old engine may just need a top end rebuild on both the cylinders. Why would you want to go messing with the ignition timing if it's just been sat?
2012 KTM EXC 250
The Artist
PostPosted: 17:07 - 15 Aug 2009    Post subject: Reply with quote
pre mix, no blue smoke. Runs on 100:1
I was told that someone may have messed with the bit that connects the ignition advance mechanism to the carb throttle.
The throttle works like this. A control cable with inner and outer pieces so it slides in and out. This cable pushes a lever which moves the ignition advance plate which in turn pushes the butterfly type carb open.
I would just like to re set the position of the carb throttle opening if that makes sense.
The last post was made 17 years, 47 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.43 - MySQL Queries: 14 - Page Size: 35.68 Kb
