| Martay |
 Martay World Chat Champion
 Posted: 20:04 - 15 Aug 2009 Post subject: Priming 2stroke oil pump |
Hi,
Just rebuilt a 2stroke 50cc scooter and the haynes book says to prime the oil pump, by cranking the engine at full throttle, with the oil pipe off the reed block into a container (plug cap removed) Oil should appear from the pipe, continue until free of air bubbles.
Following the instructions, but no oil comes out, although the tank is full and cap removed.
Is it necessary to prime the pump, if so, can you recommed a better method?
Many thanks ____________________ Eat well, poo hard
Drives: Cavalier 2.0 16v
Rides: Slightly ratted Honda City Express  |
| Billing |
 Billing World Chat Champion
| Martay |
 Posted: 20:33 - 15 Aug 2009 Post subject: |
Yeah, using electric starter. Im a bit worried about cranking it without an oil supply?
I tried sealing the pipe from the air compressor into the cap of the tank, to blow the oil through, it just made a horriffic mess! oops
Il try it again tommorow, cranking it over...
Ta  ____________________ Eat well, poo hard
| ben350 |
 ben350 Trackday Trickster
| Martay |
 Posted: 21:37 - 15 Aug 2009 Post subject: |
That sounds like a plan!
Il do that after work tommorow. Need to test run it after a top end rebuild, so killing 2 birds etc.
Many thanks
The last post was made 16 years, 315 days ago. Instead of replying here, would creating a new thread be more useful? |
