| Misc |
 Misc World Chat Champion
 Posted: 17:01 - 18 Aug 2009 Post subject: Urgent car alarm help |
Have a MK3 Golf GTI with a big problem it seems.
Went out today & got back & the remote fob didn't work, so manually used the key in the door but the engine wouldn't start/crank so i'm guessing the immobilizer is still on. Obviously i can't turn this off with the fob so the car is stuck in some carpark.
What can i do?
Cheers |
| Mrs Kickstart |
 Mrs Kickstart Brolly Dolly
 Posted: 18:08 - 18 Aug 2009 Post subject: |
Hi.
Replace the battery in the FOB/ or use the spare. Other options get expensive
Regards
C ____________________ Help fight the safety camera partnerships -- www.pepipoo.com |
| Misc |
 Posted: 18:14 - 18 Aug 2009 Post subject: |
Hey,
Tried replacing the batterys & i didn't get a spare.
It sucks because i'm not even sure of the exact model of the alarm. |
| 10 pence Short |
 10 pence Short Crazy Courier
 Posted: 18:25 - 18 Aug 2009 Post subject: |
Do the ignition lights come on when you turn it on? If so it may be worth putting a feed to the starter motor trigger. Cheaper alarms just interrupt the signal to the starter motor.
You can bypass this by finding the starter motor, usually front right above the gearbox, find the smallest wire to it and supply it with a positive feed with the ignition on.
If it starts great, if not the immobilizer may interrupt the ignition or fuel circuits. Thats a bit harder to get around.  ____________________ I haven't had a cont all day, drinkstable. |
| Misc |
| Phoenix |
 Phoenix Twisted Firestarter
| UnknownStuntm... |
 UnknownStuntm... World Chat Champion
| Misc |
| Misc |
 Posted: 15:03 - 19 Aug 2009 Post subject: |
So, got the car towed home whilst my mum went to her fav mechanic, he tells her to look at the starter motor & spray WD40 on one of the thin wires on the starter motor (he says this sots out a majority of alarm problems. We done this & key fob worked like a charm. Something so simple.
You'd of thought the recovery guy would of known this..
| 10 pence Short |
| Phoenix |
The last post was made 16 years, 166 days ago. Instead of replying here, would creating a new thread be more useful? |
