Honda NS125R-K
Tattoo Tat
PostPosted: 19:38 - 29 Aug 2009    Post subject: Honda NS125R-K Reply with quote
I got myself an R-K and it needed some work. I could only get a swing arm from a NSF as I was told it would fit. The suspension assembly doesn't line up 100% but fits, the back is a fair bit higher than before and the swing arm is an inch wider so the bolt isn't long enough.
Is it worth trying to modify the swing arm or am I waisting my time?
There is a box just under the tank on the left hand side. What is it for?
Any advice would be great.
Thanks for reading this and hope you can help
tshort2007
PostPosted: 21:16 - 29 Aug 2009    Post subject: Reply with quote
The box is a tool box, as for the rest i'm unsure. Check ebay for the proper swingarm, otherwise a modified one could screw with the handling.
Tattoo Tat
PostPosted: 12:19 - 30 Aug 2009    Post subject: Reply with quote
I thought that but there is a tool box on the back of the bike. never seen a bike with 2 tool boxes before.
The steering doesn't seem that steep even with the extra hight. It should drop a bit once I get the engine and the other bits back in place.
PostPosted: 18:35 - 30 Aug 2009    Post subject: Re: Honda NS125R-K Reply with quote
Fairly sure one from an NS125F should fit an NS125R. Do you have an NSR125 or an NS125, and is the arm from an NS125 or an NSR125?
st3v3
PostPosted: 02:20 - 31 Aug 2009    Post subject: Reply with quote
As above, NS-R and NS-F's are the same bike in different styles so parts are interchangeable.
Got any pics of troubling parts?
Tattoo Tat
PostPosted: 19:05 - 31 Aug 2009    Post subject: Reply with quote
I have an NS125 R. Its a 1989 model. Dont have any photos yet will try take some when I can find my camra.
I might just need a rear wheel from a nsf.
Will get some pics up soon as I can.
Tattoo Tat
PostPosted: 18:44 - 03 Sep 2009    Post subject: Reply with quote
Right I am still not sure about this swing arm. I have a manual for the NS125R and I covers the N125F but doesn't say If there is a difference in the swing arm. So they should be the same. I think it could be one of these reasons.
1) The swing arm isn't orignal from an F model.
2) Someone has bent the arms apart.
3) The rear wheel from an F is wider than an R.
Oh and here is a pic of the gap. Sorry the pic is fuzzy.
PostPosted: 19:43 - 03 Sep 2009    Post subject: Reply with quote
I have an NS125F in pieces and just compared its swinging arm with that on a crashed NS12R I have for spares and they are the same width.
You can see here:-
https://www.alfa-pages.co.uk/TempPicture/NsArms.jpg
Tattoo Tat
PostPosted: 12:25 - 04 Sep 2009    Post subject: Reply with quote
Thanks Keith.
When you have time could you give me the inside measurement of the swing arm and is the F swing arm made out of larger tubes than the R or are they identical?
Thanks for your help again.
The last post was made 16 years, 306 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.33 - MySQL Queries: 14 - Page Size: 59.99 Kb
