| robocog |
 robocog Traffic Copper
| bikedemon99 |
 bikedemon99 Spanner Monkey
 Posted: 23:39 - 08 Sep 2009 Post subject: |
As you said, the headlamp on a normal CG125 doesn't work with the ignition off, even if there is a battery fitted.
I think the test you're looking at is for the "parking" switch fitted to some bikes (an extra position on the ignition switch just past off. Designed primarily to trick bikers into parking their bike with the lights on so the battery is flat when they come back to it). If it isn't fitted, they can't test it. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Alexio |
 Alexio World Chat Champion
| Bishbash |
 Bishbash World Chat Champion
 Posted: 15:01 - 09 Sep 2009 Post subject: |
It's not something that is down to the oppinion of the tester. There are motorbikes which were made, brand new without a battery. They were type approved, official imports which conform fully to construction and use regulations.
Therefore it cannot be an MOT test requirement to have a battery fitted or for certain lights to work with the ignition off. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| boundy |
 boundy Nearly there...
| .Chris. |
 .Chris. World Chat Champion
| Dibble |
 Dibble Scooby Slapper
| virus |
 virus World Chat Champion
 Posted: 17:54 - 09 Sep 2009 Post subject: |
I assume you still have a battery?
In which case do not remove it, the amount of hassle it will take to find a capacitor suitable to replace it at such a level that your lights still work its not worth removing, without a battery/cap everything will dim when your revs go down or more lights go on, and a MOT man will find that unsafe.
Cheers
John ____________________ own: 81 xs1100g...
stinkwheel Well I just had my hands up a pigs fanny. Which makes your concerns pale into insignificance. |
| robocog |
 Posted: 18:27 - 09 Sep 2009 Post subject: |
Ok cheers for all the replies
Will ask the place that will eventually do the MOT
I am not at the MOT stage yet, but its now a rolling chassis and engine is hopefully going in tomorrow...so sorting some kind of simple loom will be next on the list and will have to have some sort of plan of attack as to what is needed
Stinkwheel
I see what you mean about the park lights, I don't recall either of my CG's having the extra key position just on or off- but the CJ360 does have an extra one (one click after the ignition that cuts ignition and allows the key to be removed and flatten battery by magically putting park lights on)
so perhaps that is what is meant by the paragraph I posted and I have read something into it I shouldn't have -
their wording is a bit ambiguous
The only differences between the CG I have on the road to this one is the indicators,horn and possibly brake light without engine physically running (but key in run position) so as the wording allows for this I can't see it really being an issue, but I will check prior to MOT as I suppose I could fit a battery in the seathump, but was reserving that space for transportation of lunchtime sandwiches and the like
(the area that once housed the battery would ideally be left open - bar the air filter)
Its not the cost of the battery (I even have one for it that seems OK)
Could just do without the added weight-that would only in reality get used to tell me I'm in neutral prior to kicking it over (I think 'rock the bike first' or simply pulling the clutch in will allow me to kick-start in gear on this engine?...it doesn't on the CJ which struck me as odd!)
I want all 10Hp to go as far as possible (without it becoming a wallet emptying excersize!)
My CG that is on the road (with a charged battery) suffers from low RPM headlight dimness, but fine when above tick over
think they all do that don't they?
as it runs direct from the genny , not the battery?
fairly sure if mine stalls the headlight goes off completely, despite having a battery
Indicators and horn and neutral light and IIRC brake light are the only things that /seem/ to be running from the battery on the "good one"..perhaps this is not wired right but has just 'got away with it'?
(not studied and digested the wiring diagram yet)
Once again cheers for all the replies
Will ask the local MOT places to see what their views are on it and base who I take it to depending on what they answer
Hoping it will turn out to be a locost,lightweight and fun commuting toy which will easily break the 100mpg and raise a giggle
Regards
Rob |
| andyscooter |
 andyscooter World Chat Champion
The last post was made 16 years, 363 days ago. Instead of replying here, would creating a new thread be more useful? |
