NSR125 Repair and Tidy Up
RichP
PostPosted: 22:48 - 13 Sep 2009    Post subject: NSR125 Repair and Tidy Up Reply with quote
Thought i'd do a little bit of a blog on getting this bike sorted out since as usual its ended up being more than I thought!
I initially bought the bike as a non-runner, it had an electrical fault but when I went to view, it seemed to have no compression... I could bump it over easily in any gear. Anyway after a some bargaining I purchased it and got it 'vanned back home to start work.
Here's where I started from:
https://img24.imageshack.us/img24/5550/bikei.jpg
Got it into the garden and started stripping. (i later moved to the garage when the sun went in and the rain came out!)
https://img441.imageshack.us/img441/6571/ranomage004.jpg https://img441.imageshack.us/img441/ranomage004.jpg/1/w640.png
The electrical fault was found rather easily, it was a break in the green wire to the clocks, I spliced it back together... I found the previous attempt to mend it by instead of looking for the break, cutting into the wire further up and putting in another amusing.
https://img41.imageshack.us/img41/4347/ranomage003.jpg https://img41.imageshack.us/img41/ranomage003.jpg/1/w640.png
I stripped off the head and barrel to find a rather knackered piston (sorry no pics right now), rings completely seized in and the top looked like it had had a rodent chewing at it!
With some difficulty removing the gudgeon pin I fitted a new piston and rings, slapped it all back together and tried to start it.
It fired up but with a pretty loud knocking noise... Big end, bugger!
So i've just sourced a bottom end off baldy, picked it up today and currently have it in bits to work out how it all goes together!
https://img98.imageshack.us/img98/462/ranomage002.jpg https://img98.imageshack.us/img98/ranomage002.jpg/1/w640.png
I'll need to scavenge some bits off my bottom end to complete this one, i'm also tempted to get the workshop manual printed out in full! Its a pain to look through in .doc format!
Apart from that its mainly cosmetic work, cleaning, missing fairing bolts, cracks etc, i also need a new ignition lead if they sell them, mines cracked and the bit inside the plug keeps falling out!
I've bodged a car one to fit temporarily.
Will try and get photos and keep up to date with progress as i go!
BenR
PostPosted: 17:21 - 14 Sep 2009    Post subject: Reply with quote
Was this on egay last week? Looks nice! Once you've got the engine sorted should be a belter. Thumbs Up
RichP
PostPosted: 22:23 - 16 Sep 2009    Post subject: Reply with quote
Yep, found on ebay... Not to sure if the owner genuinely didn't know what was wrong... Or was trying to con me lol!
Either way, bikes more stripped down now but ala my post about it in the workshop theres a bloody seized engine bolt thats twisted my socketed allan key right around.
Also need to make sure the oil pump is working correctly, i shall be premixing until i'm sure!
Does anyone know if its normal for the wiring loom to be run through the grey holder part for the fake air intakes..?
Cheers!
Mystery
PostPosted: 14:43 - 17 Sep 2009    Post subject: Reply with quote
Cheers!
yeah its for your indercaters and just to the left the wires for the clocks and headlight as well
RichP
PostPosted: 22:14 - 19 Sep 2009    Post subject: Reply with quote
Carrying on from before, I had to take the whole kickstand bracket and assembly out to drop the engine because i couldn't unseize the bolt.
Ended up having to get a new one because I couldn't get the bolt out on the bench either!
Here's the new one refitted.
https://img193.imageshack.us/img193/5628/rebuild001.jpg
And then i had to reconnect the shock to it, my crude method with no paddock stand involved laying the bike on a cushion to take the weight off haha.
https://img44.imageshack.us/img44/3916/rebuild002.jpg
Look at those nasty cracks...
https://img12.imageshack.us/img12/91/rebuild003.jpg
Good job i just picked up these!
https://img524.imageshack.us/img524/137/rebuild005.jpg
Now the bike is back on its sidestand again (Woohoo!) I shall give it a good major clean tomorrow while i've got access to everything.
https://img6.imageshack.us/img6/5591/rebuild004.jpg
Next i've started on swapping parts across and building up my new engine.
My improvised work area!
https://img246.imageshack.us/img246/9421/rebuild006.jpg
First order of business is to strip the head and barrel off the old one, then i'll swap across the starter motor, generator cover and oil pump.
Currently stopped till i get the Generator cover off!
https://img193.imageshack.us/img193/2323/rebuild007.jpg
Mystery
PostPosted: 23:39 - 19 Sep 2009    Post subject: Reply with quote
you think yours is dirty mines hasn't been washed since it got out the show room i dont think, i've stripped mines down as well to give it a good clean out not dropping the engine though Thumbs Up , got a dodgy wiring prob with mine to stop it from running right as well Thumbs Down
RichP
PostPosted: 00:09 - 20 Sep 2009    Post subject: Reply with quote
https://www.youtube.com/watch?v=HREqf4wIukA
That set of guides is awesome!
I wouldn't go as mad as he did but i'll give it a damn good go! Very Happy
I wish i'd known how effective WD and a toothbrush was on my last bike!
Well ive swapped the starter motor across from my old bottom end, need some bottom end gaskets now so i can fix my generator cover on... Don't know who will have them locally on a sunday... Liquid Gasket lol!
Trying to decide what to do with the chain and sprockets, it needs new ones but they're still servicable... Probably go the winter with them, plus i'll feel the difference more!
I need to drain the transmission oil from the old one now so i think i'll call it a night and fry up some chicken i've got in the fridge. Very Happy
RichP
PostPosted: 22:19 - 21 Sep 2009    Post subject: Reply with quote
No pics for this update, i can't be arsed to upload them right now.
Engine is back together (finally), and its gone back into the bike.
Thought before i finished up i'd have a quick try and start it, turned it over compression good. So i hooked up all the electrics, pushed the carb back on a jubilee clipped it, hooked up the fuel feed (i've premixed the fuel till i determine if the oil pump is working).
Turned it over... Nothing.
After tons of fiddling, by lifting the plug out it seems no fuel is getting in, can't think why.... Also when i turn the air out it feels as if air is being blown out somewhere down the left side, can't put my finger on where...
BASTARD FUCKING THING! WHY CAN'T SOMETHING WORK FIRST TIME!
Sorry, needed to get that off my chest! Very Happy
baldy
PostPosted: 03:00 - 22 Sep 2009    Post subject: Reply with quote
That's why i didn't rebuild that engine, because i knew it would be a ball ache.
Did you turn the fuel on?
One day i will rule the world, just not today.
Billing
PostPosted: 03:09 - 22 Sep 2009    Post subject: Reply with quote
put something like clutch cleaner or wd40 on the outer edges of where the gaskets are, then try turning it over with some force, any air leaks will be apparent because it will 'puff' the fluid out of the way Thumbs Up worked for me and my ts125 head gasket
Welshd1k
PostPosted: 13:06 - 22 Sep 2009    Post subject: Reply with quote
while you got it in bits check the pipe for the restrictors
RichP
PostPosted: 16:26 - 22 Sep 2009    Post subject: Reply with quote
Leaving it restricted till i get the proper jets in etc!
RichP
PostPosted: 07:43 - 25 Sep 2009    Post subject: Reply with quote
Will do a proper post this evening with pics etc... But at half one in the morning i moved it across the garage under its own power! Very Happy
RichP
PostPosted: 20:25 - 25 Sep 2009    Post subject: Reply with quote
Ok the bike is now running and on the road!
At the moment it has a huge flat spot between 5 and 8, this is (i think) a combination of not connecting the powervalve up yet (so stuck open), way to much oil in (premix and the oil pump... better safe then sorry when bleeding oil pumps) and consequently a very oiled up plug... i have a replacement as soon as this tank of fuel is through...
Some pictures of the various bits of it, and i will at some point get a video of the bike in action.
https://img185.imageshack.us/img185/6458/dsc00129l.jpg https://img185.imageshack.us/img185/dsc00129l.jpg/1/w640.png
https://img62.imageshack.us/img62/9277/dsc00130d.jpg https://img62.imageshack.us/img62/dsc00130d.jpg/1/w640.png
https://img260.imageshack.us/img260/8012/dsc00131.jpg https://img260.imageshack.us/img260/dsc00131.jpg/1/w640.png
https://img97.imageshack.us/img97/989/dsc00132cl.jpg https://img97.imageshack.us/img97/dsc00132cl.jpg/1/w640.png
Giving the chain a bit of the old mega clean:
https://img524.imageshack.us/img524/1744/dsc00133w.jpg https://img524.imageshack.us/img524/dsc00133w.jpg/1/w640.png
Currently left to do, connect up power valve... Means removing the radiator... bugger!
Put all the fairings on, and a load of minor jobs i can't remember right now!
BUT ITS RUNNING! Very Happy Very Happy
The last post was made 16 years, 355 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.86 - MySQL Queries: 13 - Page Size: 86.48 Kb
