Yamaha water pump oil seal
mlbbrown
PostPosted: 20:02 - 19 Sep 2009    Post subject: Yamaha water pump oil seal Reply with quote
Hi there,
I recently acquired a Yamaha.
It's registered as being a TZR125 but after some intensive googling of the frame/engine number (4AP-045854) we're fairly certain it's a TZM150. A model which is usually found in Malaysia/Singapore.
Having measured the cylinder, it's definitely a 150cc engine. Radius ~3cm, TDC to BDC is ~5.4cm
Anyway, the main problem - The oil seal in the water pump needs replacing. Water was getting into the transmission oil through it and emulsifying.
I can't find anywhere that does spare parts for the TZM150. Is the seal likely to be standard across the models ? Ie, is it the same as the seal in the TZR125 ?
Thanks,
Matt.
PostPosted: 20:13 - 19 Sep 2009    Post subject: Reply with quote
It's probably the same, and probably replaceable. Someone put the steel shaft through the alloy housing so it should be possible to remove it. You might find that it's a non-standard size only available from Yamaha.
The last post was made 16 years, 359 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.04 - MySQL Queries: 14 - Page Size: 31.61 Kb
