Forks!
DazHornet
PostPosted: 18:16 - 24 Sep 2009    Post subject: Forks! Reply with quote
Ive done loads and loads of forks before but these ones are taking the piss ha
got one fork done. new seals and oil ... all good.
second fork is ready to be pulled apart. i cannot for the life in me get the bugger apart. everything is out that should be out.
anyone know a better way of getting either the oil seal out or the forks apart please??
PostPosted: 18:37 - 24 Sep 2009    Post subject: Reply with quote
Grip the stanchion above the working part in a padded vice and repeatedly pull the leg sharply away from it. The bushes should eventually force the seals out in a slide-hammer action.
Failing that, put the springs and caps back in and clamp it like before. Compress the spring fully to the stop and let go. Repeat until the end of the fork flies across the workshop and puts a big dent in your car door.
If it's being recalcitrant, try bracing the bit of the casting that the seal is in against a block of wood and giving it some sharp taps all the way round with a deadblow hammer then repeat the above.
If it absolutely will not budge, try filling it totally to the brim with water, replacing the cap and hitting the top of the fork with a mallet while you have the fork stood upright on a padded surface. The water pressure ought to force the seal out. (ought to, I'm not making any garauntees).
The last post was made 16 years, 170 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.52 - MySQL Queries: 14 - Page Size: 32.04 Kb
