New barrels
pazif
PostPosted: 17:06 - 02 Oct 2009    Post subject: New barrels Reply with quote
Hi ive got a CB 125 superdream.
when i got it it had a oil leak. the oil was coming out of the breather pipe on top of the gearbox.
i brought new barrels (came with pistons, piston rings and top end gasgets) i fitted them and the bike is fine.
my question is, how should i ride in the new barrels.
i started only ridding at 5k rpm for the 1st 100 miles and then 6k rpm for the next 100 miles. now i keep under 7k rpm.
i was told i need to cover 500 miles, going up an extra 1k rpm each time i complete 100 miles.
is this right??
thnx for any help
MaybeGuy
PostPosted: 17:44 - 02 Oct 2009    Post subject: Reply with quote
i'd thrash it properly for a bit per 100 miles on top of that.
prawny1
PostPosted: 15:57 - 03 Oct 2009    Post subject: Reply with quote
Its best not to thrash a fresh engine, but imo the so many revs for so many miles isn't realy needed just dont load the engine (full throttle etc) for a few hundred miles and whilst your cruising alternate between fifth and forth, so you don't get hot spots on the new bores,
Tbh if you haven't changed any of the crank bearings etc, the running in will be just to settle your new rings in, as it will take several thousand miles for the pistons to properly bed in anyway on a four stroke.
an oil change after the first few hundred miles wouldn't be a bad idea and cleaning the filter gauze thing just for piece of mind.
PostPosted: 15:59 - 03 Oct 2009    Post subject: Reply with quote
Even if he had done the crank bearings, they don't require running in. If bearings are bedding in there's something wrong.
prawny1
PostPosted: 16:04 - 03 Oct 2009    Post subject: Reply with quote
Are these engines plain bearings or roller bearings? fair enough roller bearing won't realy need runing in but plain bearings will to stop any tight spots picking up and trashing the bearing.
The last post was made 16 years, 229 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.18 Sec - Server Load: 1.53 - MySQL Queries: 14 - Page Size: 44.65 Kb
