wohoo fixed it
Evilbob
PostPosted: 21:24 - 30 Jul 2003    Post subject: wohoo fixed it Reply with quote
finally fixed the ktm250 and it sodding boots but is very funny running
a) if it run outa fuel -> idle increases also and eventually starts going mental and have to use kill switch
b) air screw was all the way in
c) throttle cable adjuster to get rid of slack was holding throttle open
d) errr still goes really fast but doesn't change from low end to top end very well , better in 5th?????
e) drinks fuel Smile chains arm and scars the cack out me Cool
anyway here what i have dun and i now erem dont start lol (hate carbs Crying or Very sad )
a) air screw 1.5 turns (as ktm spec)
b) adjusted cable so it as closed as possible
c) tick over was like damb open but didnt make a difference b4 so closed it then added 4 turns
any ideas lads??? (& lasses)
(its now got black frame and fenders are orderd going to be rude)
my karma is dieing not fair who cares about spelling? i get the point across, most of the time Smile
Evilbob
PostPosted: 22:00 - 02 Aug 2003    Post subject: k Reply with quote
must have kick the damb thing over about 500 times past 2 day and have now played with the timing
before it was like 20 degrees and only ran with wacky carb settings
now its about 8 degrees and runs with vagly normall carb setting but still working on it
Any body got a good explination what the effect of this is??? or some ideas on whats going on???
supost to be 12 ish i think?!?!?! but theres 2 main postions and then +-5 degrees either side
Evilbob
PostPosted: 15:30 - 03 Aug 2003    Post subject: ARARAR Reply with quote
ARARARARARRARA
right with 8 degrees ish its alot better at starting but now i have changed back o non resistor plug but it got decent ie normall carb settings ie throutle closed air screw open a bit and it ticks over
so now i am thinking that it was carb setings were wrong and the sparky didnt help so advance the timing a bit more?!??!?!
ANY BODY ALIVE OUT THERE ?!?!?!?!?!
1 of u lot must have some tuning experence Crying or Very sad
PostPosted: 15:41 - 03 Aug 2003    Post subject: Reply with quote
the visordown.com/forum/ workshop forum has a lot of people in there who know nearly everything there is to know. Might be worth popping a post up over there?
PostPosted: 15:56 - 03 Aug 2003    Post subject: Reply with quote
How is the timing meant to be set?
Most of the time there is a static timing mark. You set this using a dial gauge in the spark plug hole. Once it is set statically you can test it with a strobe light. The timing will vary with engine revs.
Try and route the cable so that there is free play whichever way the bars are turned.
The high revs as it runs out of fuel is quite usual.
If the air screw has been tightened all the way in then it can be damaged.
What fuel are you using? It would not surprise me if it is meant to run on higher octane fuel than normal 95 RON unleaded.
Check the needle jet position. Someone may have altered that in the past which could cause problems in the mid range
Evilbob
PostPosted: 21:25 - 03 Aug 2003    Post subject: Reply with quote
it like increases revs toward red line ??"?"?"? and i have to pull the plug cap ( or now hit the kill switch)
Evilbob
PostPosted: 23:01 - 09 Aug 2003    Post subject: carb Reply with quote
year baby,
stater plate was in wrong postion and then its also varible sorted it out witha fellow exc owner and its the bo**ocks Smile
starts first kick
doenst go mental (unless u open her up Twisted Evil )
power is LOVLEY<
(dancing, dancing , dancing , dancing )
Cool Cool Cool Cool Cool Cool
i rock
WildGoose
White Van Man
PostPosted: 17:43 - 10 Aug 2003    Post subject: Reply with quote
glad you sorted it mate, been over to the track with it yet?
push push Razz
The last post was made 23 years, 58 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.51 - MySQL Queries: 14 - Page Size: 59.33 Kb
