| Dan79 |
 Dan79 Scooby Slapper
| Alexio |
 Alexio World Chat Champion
| ms51ves3 |
 ms51ves3 Super Spammer
| unitybiker |
 unitybiker Nova Slayer
| 27cows |
 27cows World Chat Champion
 Posted: 06:25 - 30 Nov 2009 Post subject: |
I encountered this scary phenomenon just once - and it was down to dodgy alternator wiring and led to me having to ride 30 odd miles home with the flywheel cover removed - so no clutch, no gearchange (3rd all the way) and the flywheel spinning at 9000 revs two inches from my leg I managed the whole journey without stopping LOL
I'd bought some bits for next to nothing, including a stator. Don't know why I decided to try it out as the one on the bike worked fine. But I never used it again after that incident and I've never experienced anything of the kind before or since.
Wet weather is never a problem for my RXS. Electrical grease is marvellous stuff  |
| Kickstart |
 Kickstart The Oracle
| bladerunner |
 bladerunner World Chat Champion
 Posted: 11:46 - 30 Nov 2009 Post subject: |
agreed it sounds more electrical as it does it only in the wet. I'd suspect that the plug is getting water on it or the ht lead or cap are arcing out to earth and after a few seconds the heat from the engine could dry off the water enough to clear up again. 2 strokes do sometimes suffer this a little more as the plug sits on top of the head exposed to spray off the front wheel more than a 4 stroke but thats not to say it's a 2 stroke thing at all and a new cap or rubber pipe over your ht lead should stop the issue for you.
PS if it's one of those old metal ht caps you have plz throw it in the bin anyway...what a stupid idea that was!!!  ____________________ Current bikes...cbr929, KDX200's, Rd125lc mk2, RGV250's |
| Kickstart |
| lexx86 |
 lexx86 L Plate Warrior
| Kickstart |
| lexx86 |
| Kickstart |
 Posted: 13:36 - 30 Nov 2009 Post subject: |
Assuming you mean backfires from the exhaust then sounds like it has dumped a load of fuel down there. Could be the engine is really badly flooded (same for the exhaust, but at least you can take the exhaust off to drain it out). It is worth checking the timing though.
If you mean backfiring back through the carb then definitely check the timing and also check the condition of the reed valves.
| lexx86 |
| Kickstart |
 Posted: 15:08 - 30 Nov 2009 Post subject: |
Not really much to adjust on the reeds. Reed stops can be bent out further but unlikely to need bending to correct anything. Reeds tend to be pretty much maintenance free until you bin them.
Not sure how he would prime the oil line if the engine isn't running. You get prime the line to the pump easily enough but not really from the pump to the engine.
| lexx86 |
| Kickstart |
| 27cows |
| lexx86 |
| Alexio |
 Posted: 19:02 - 30 Nov 2009 Post subject: |
If water in the electrics is the problem then you need to be attacking your bike with lots of WD40  ____________________ will never give up his CG. I look at my fuel gauge more as a progress bar than a fuel gauge.
ms51ves3: why does it need 500 miles? Are you teaching it how to be a piston? |
| 27cows |
 Posted: 19:25 - 30 Nov 2009 Post subject: |
And once you get it sorted, keeping the water out with electrical grease  |
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 19:48 - 30 Nov 2009 Post subject: |
1990 energy induction RXS's are CDI, not points.
try the sparkplug, check the carbs set up right etc.
the one i built did this sometimes too. it was a fucked float valve. I tried cleaning it out, but it was worn and scored so i just replaced the whole carb for a tenner from the breakers rather than buying a new one and waiting for it to arrive. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| 27cows |
| MaybeGuy |
 Posted: 21:07 - 30 Nov 2009 Post subject: |
your right. it CANT be the bikes problem, it must be you! RXS's are invincible. im sorry for doubting them  ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| 27cows |
| Dan79 |
The last post was made 16 years, 296 days ago. Instead of replying here, would creating a new thread be more useful? |
