Zepf |
Zepf Renault 5 Driver
TiN |
TiN Pocket Tin
Posted: 18:29 - 20 Aug 2003 Post subject: |
You mean the brake caliper, yeah? The reservior should be mounted on your handle bar.
You've most likely got air in the brake system, which means that it'll need bleeding. Take a peek in the FAQ section for a guide on bleeding your brakes. ____________________ TiN
dotgems.net |
Zepf |
Zepf |
TiN |
TiN Pocket Tin
Posted: 18:40 - 20 Aug 2003 Post subject: |
Yes, it's your brake lines that need bleeding. "Brakes" covers your caliper(s), reservoir, and line(s). Fluid is pumped from the reservoir through the line(s), and to the caliper(s). If you get air in your brake line they will feel spongy (if you can feel anything at all that is). ____________________ TiN
dotgems.net |
Zepf |
Posted: 18:44 - 20 Aug 2003 Post subject: |
Is this the FAQ your talking about: https://www.bikechatforums.com/viewtopic.php?t=17818 ??
As it doesn't actually explain how to do it..
Zepf
P.S. Sorry if i sound retarded, disc brakes and all the components are new to me.. ^_^ |
TiN |
TiN Pocket Tin
Zepf |
TiN |
TiN Pocket Tin
Posted: 18:51 - 20 Aug 2003 Post subject: |
Ideally, although the primary use of the hose isn't for checking if air is coming out, but more to ensure that brake fluid doesn't dribble nicely all over your caliper. ____________________ TiN
dotgems.net |
Zepf |
TiN |
TiN Pocket Tin
Posted: 18:55 - 20 Aug 2003 Post subject: |
No probs, and good luck! ____________________ TiN
dotgems.net |
Scooby |
Scooby Scrappy Doo
Posted: 19:11 - 20 Aug 2003 Post subject: |
One more thing. Whatever you do don't get any on your wheels ____________________ A big enough hammer fixes anything! |
The last post was made 20 years, 257 days ago. Instead of replying here, would creating a new thread be more useful? |
