Tyre mix advice please
krytenboog
PostPosted: 20:24 - 16 Dec 2009    Post subject: Tyre mix advice please Reply with quote
I have a Kawasaki GT550 g9 1989 .Today I obtained a rear tyre, Avon Super Venom am18 on a decent wheel for the bike. On the front I have a Bridgestone Battleax. Is it ok to fit the Avon on the rear and so have tyres from different manufactures? , Im thinking of just changing the rear wheels over as the tyre is already fitted and balanced to the wheel it came with.
Thanks
yen_powell
PostPosted: 20:58 - 16 Dec 2009    Post subject: Reply with quote
Are they both radials? Don't think you can put a radial on the front and a crossply on the back, fine the other way round though. I wouldn't worry about mixing makes though as long as they are both the right sizes and speed ratings.
XT1200Z and a DR350 in bits
krytenboog
PostPosted: 21:30 - 16 Dec 2009    Post subject: Reply with quote
Thanks, they are both radials and the right size etc, just thought I had better check
Blue_SV650S
PostPosted: 21:34 - 16 Dec 2009    Post subject: Reply with quote
Yep, I do this sort of thing all the time!! Thumbs Up
It should be noted that 'matched pairs' are just that, the profiles of them are coincidental so they give the most predictable handling characteristics. A mix and match will be just that, so the bike probably won't handle quite as well as on a matched pair .... some mix and match pairs will work well together, others will 'fight' each other a bit, so be more noticeable.
In summery, yes you can do it, but it MIGHT not handle as well as on a matched pair ... but if you are simply using the bike to commute ... who cares?!!? Wink
temeluchus
PostPosted: 06:05 - 17 Dec 2009    Post subject: Reply with quote
incidentally both are crossplies, not radials.
PostPosted: 09:27 - 17 Dec 2009    Post subject: Reply with quote
i use a BT45 on the front and a Conti Twist SM on the rear
I found this to be quite a nice setup for me...shed loads of rear grip and the faith i have in the bt45 is why the front is like that Razz
The last post was made 16 years, 291 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.28 Sec - Server Load: 2.23 - MySQL Queries: 14 - Page Size: 47.25 Kb
