Kick start moped
ray 316
PostPosted: 18:00 - 17 Dec 2009    Post subject: Kick start moped Reply with quote
Can you kick start a moped and run a without the battery connected and would the key have to be used. If you can it's a easy way to nick a bike.
The Artist
PostPosted: 18:16 - 17 Dec 2009    Post subject: Reply with quote
You don't need a battery on most.
You do need a key on most.
TQ
PostPosted: 18:18 - 17 Dec 2009    Post subject: Reply with quote
The question applies to bump starting bikes just as much as kick starting mopeds.
The key is needed as the ignition switch normally controls the spark (e.g. no key, no spark).
First Bike :Gilera DNA 50 | Second: Imported 1989 NSR125
Third: 1998 Yamaha XJ600N | Currently: 1999 Yamaha FZS600
27cows
PostPosted: 18:34 - 17 Dec 2009    Post subject: Reply with quote
On many small bikes, all you need to start them is a cross head screwdriver. Undo the headlight, disconnect the ignition switch block and the bike will start, battery or no battery.
PostPosted: 18:42 - 17 Dec 2009    Post subject: Reply with quote
Doesn't anybody use logic any more?
Why would manufacturers sell mopeds that can be started without a key? Mopeds are bad enough for theft without allowing them to be ridden away with no security measures at all.
We need a rating that says "If you had have thought about that you would have come upon the answer yourself rather than having to waste our time".
27cows
PostPosted: 18:49 - 17 Dec 2009    Post subject: Reply with quote
It's not just mopeds. Many bikes will spark once the ignition switch block is disconnected. It's a common way of eliminating a faulty switch if you have running problems - disconnect it and if the problem continues, you know there's nowt up with your ignition switch.
Maybe bike theft isn't a big problem in Japan Surprised
PostPosted: 18:52 - 17 Dec 2009    Post subject: Reply with quote
My Chaly sparks when you un-plug the ignition switch. I would say it started, but it didn't.
ray 316
PostPosted: 20:34 - 17 Dec 2009    Post subject: Reply with quote
No wonder mopeds/scooters are pinched so easy..
You do not need a battery to start it, you can use the kick start ... fair enough but you need the key. Or Undo the headlight, disconnect the ignition switch block and away you go Wink .
So what is the battery's needs is it just for the lights/ indicators/ horn and the electric start..
27cows
PostPosted: 20:53 - 17 Dec 2009    Post subject: Reply with quote
Quite a few small bikes only use the battery for horn, indicators and brake light. Headlight only works with the engine running. Older bikes that mostly is, particularly those with 6V electrics.
Jamie S
PostPosted: 21:24 - 17 Dec 2009    Post subject: Reply with quote
A mate of mine who has an Rs50 showed me how he could get his bike going with no key, and with out removing any pannels and using any tools , very simple and only invloves removing one connector, the bike can then be bump started and road away...... Shocked
prawny1
PostPosted: 23:15 - 17 Dec 2009    Post subject: Reply with quote
Most scooter ignition barrels control the steering lock and a basic two wire on off switch, both are easily bypassed using a few screw drivers.
The mosty effective way most scooters are protected is by having an immobiliser system that uses a transponder and sensor ring, so no key means no spark even if you gain access to the black box/ignition switch.
You can rewire the cdi unit to bypass the immobiliser but some bikes have monocolour cdi wiring, with those a knowldege of the specific bikes loom is needed.
crackpotterpi...
PostPosted: 00:30 - 20 Dec 2009    Post subject: Reply with quote
my step daughters cagiva moped was nicked out the back yard 2 days ago we got it back later the next day they just unplugged the ignition switch and you could kick start it,no shorting or connecting of wires needed! only bad thing is they made a bit of mess when they broke the steering lock off and its not insured as I bought it for her birthday next month!! thieving sh**s!!!!! Smile I believe the honda cg is the same and several other smaller bikes watch out!!
1990 jc20 nsr125-sold,2003 cg 125-sold currently no bike.........might get another 2 stroke me thinks much more fun
PostPosted: 20:44 - 20 Dec 2009    Post subject: Reply with quote
mates mum has a lambretta...like very old 125.. that has no key, like no ignition at all!!
mental thing, was kicking it and it started...needless to say i shit myself!
The last post was made 16 years, 239 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.66 - MySQL Queries: 13 - Page Size: 79.36 Kb
