Removing 33BHP Restrictor
Kirky
PostPosted: 10:54 - 21 Dec 2009    Post subject: Removing 33BHP Restrictor Reply with quote
Hi can anyone help me.
I've just got a GFS 600N bandit, but it is fitted with a 33BHP Restrictor.
What I want to know is how to remove the washers from the carbs.
Any help would be greatfull.
PostPosted: 11:04 - 21 Dec 2009    Post subject: Reply with quote
Normally between the carbs and the engine.
If so, take the seat and tank off. Undo the clamps holding the airbox to the carbs, and unbolt the airbox from the frame. Slide the airbox back as far as it will go. Undo the clamps holding the carbs to the inlet rubbers, and pull the carbs back. With luck you can then slide the carbs out of the way and get the washers out. However you might have to remove the carbs in which case you will probably have to remove the throttle cable/s.
All the ebst
Kirky
PostPosted: 12:29 - 21 Dec 2009    Post subject: Reply with quote
Thats great, thanks for your help. Thumbs Up
The last post was made 16 years, 265 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.22 - MySQL Queries: 16 - Page Size: 35.56 Kb
