| Moo. |
 Moo. World Chat Champion
| Alexio |
 Alexio World Chat Champion
 Posted: 15:59 - 11 Jan 2010 Post subject: |
It could be the cold weather. Are you brave enough to open up the carb and have a look? That would at least let you know if all is clean. If so it probably is the cold.
Solution: take hair drier / blow torch to carb to warm it up. Once warm see if bike behaviour is back to normal  ____________________ will never give up his CG. I look at my fuel gauge more as a progress bar than a fuel gauge.
ms51ves3: why does it need 500 miles? Are you teaching it how to be a piston? |
| Moo. |
 Posted: 16:06 - 11 Jan 2010 Post subject: |
Yeah its boggling me, had it apart a few times, its clean as a whistle in there.. even changed the needle for a slightly narrower one incase that was sticking.
As far as i remember, it didnt do this before the cold. But it just seems like a really odd problem.
Another idea, could the bolts off the engine, which it slides onto be slightly out of alignment? So when its tightened, it pushes it together?
Cheers for the hair dryer idea  ____________________ A2 Passed 18/6/10 |
 . Renault 5 Driver
| Moo. |
 Posted: 16:20 - 11 Jan 2010 Post subject: |
It is a tad annoying not being able to close the throttle.. or pull in the clutch and hear it scream.
It usually happens when the throttle is open wide, not in the start. I can tell its the slide thats stuck because i can still move the throttle, it just does nothing, can feel the cable going up and down aswell.. ____________________ A2 Passed 18/6/10 |
The last post was made 16 years, 242 days ago. Instead of replying here, would creating a new thread be more useful? |
