| Blunet600 |
 Blunet600 Nearly there...
| The Artist |
 The Artist Super Spammer
| Blunet600 |
| Kickstart |
 Kickstart The Oracle
 Posted: 22:53 - 25 Jan 2010 Post subject: |
Reason for a multigrade oil is that it acts like a (say) 5 weight oil when cold and a 40 weight oil when hot. But a cold 5 weight oil is probably still thicker than a hot 40 weight oil.
Thinner oils get pumped round more quickly on startup. However the oil acts as a barrier between engine parts and you need a thicker oil when it warms up to compensate for the oil thinning.
While you could just use an oil with a wider viscosity range, that requires more additives which break down (the oil itself lasts far longer), and so you land up with a shorter lived oil (main reason synthetics are better is that they are less reliant on additives, hence wear out more slowly and can have longer oil change intervals).
| P. |
 P. Red Rocket
| The Artist |
| Blunet600 |
| WildGoose |
 WildGoose White Van Man
 Posted: 18:36 - 26 Jan 2010 Post subject: |
Thats merely a little light reading
Try this:
https://motorcycleinfo.calsci.com/Oils1.html
Explains all about additives, and their breakdown, and the difference between synthetic and mineral based oils. Although don't take it all as gospel because he says a lot of speculative things that aren't backed up with evidence to support them.
It's all really quite dull stuff, unless you are into that kind of science. It entertains me, because I like reading the comments on multiple internet forums from so called experts, who are talking absolute rhubarb.
"Has to be castrol in /that/ bike" etc and other such wibble.
Go with the oil weight recommended by the manufacturer for your climate, not necessarily the brand. Then sack off the likes of Castrol and Mobil 1 and buy the cheap equivalent from someone like Comma, found at most motor factors, and change it regularly.
There is a fair bit of evidence to suggest that anything marketed as "motorcycle oil" is just preying on the ignorant, as an excuse to charge way over the odds. It works of course, because most people don't care to do a bit of research.
The fact remains that you will be rid of your well bike before your oil choice next to another will make any real difference. ____________________ So in other words, he stopped you for being flagrantly in posession of a motorcycle in direct contravention of the Hippies, Darkies and People Whose Face I Don't Like The Look of (Police Powers) Act. 1976 |
The last post was made 15 years, 331 days ago. Instead of replying here, would creating a new thread be more useful? |
