honda varadero 125 cutting out on low revs after a run
timboellis
PostPosted: 22:10 - 26 Jan 2010    Post subject: honda varadero 125 cutting out on low revs after a run Reply with quote
My honda varadero 125 has been good as gold gven lots of long runs but just recently found a very odd thing happening.
If I go for a run of say 10 miles or more where is it sitting in top gear at 55-65 most of the way when i get back into the town it does nto want to idle properly causing me to have to set the revs at 7-8k or stall just to pull away in 1st and it feels like i am trying to pull away in 2nd.
However about the town driving it is great starts first time no probs at all.
Any suggestions?
MaybeGuy
PostPosted: 22:39 - 26 Jan 2010    Post subject: Reply with quote
running on 1 cylinder?
Alexio
PostPosted: 22:53 - 26 Jan 2010    Post subject: Reply with quote
It could be any number of seemingly insignificant maintenance issues. Or it could be running lean once the engine warms up?
Lukaz2205
PostPosted: 18:54 - 09 Feb 2010    Post subject: Reply with quote
firstly, when were your valve clearances checked? make sure that you have the right mixtures and that your spark plug leads are on securely. also, you checked that your choke isnt on?
im going to go with valve clearances...
1st....2nd....3rd....4th.....into 5th......6th field and stopped in a heap!
timboellis
PostPosted: 10:09 - 10 Feb 2010    Post subject: issues Reply with quote
Well think i just sussed it out yerterday and nothing to do with the engine at all(Thankfully) I believe it was the front brakes, as I put new pads on a few weeks ago, small runs are fine but if I take it or a long run when i bled the brakes last time I left very little space for expansion and now finding when it heats up it is jamming the brakes on and I just never noticed the brakes sticking.
Thanks for th esuggestions though
truslack
PostPosted: 10:37 - 10 Feb 2010    Post subject: Re: issues Reply with quote
You shouldn't need to. Remove and clean the brake pistons, the seals may also need replacing.
timboellis
PostPosted: 10:58 - 10 Feb 2010    Post subject: brakes Reply with quote
Well i had them cleaned as there were a lot of crap on the pistons themselves which i managed to get off and its like night and day now
The last post was made 16 years, 190 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.57 - MySQL Queries: 14 - Page Size: 52.41 Kb
