Baotian drive belt
stuartadair
PostPosted: 22:30 - 20 Jul 2010    Post subject: Baotian drive belt Reply with quote
Now before you start shouting at me, the scooter belongs to No1 Son who's doing it all for his 16th Birthday... Wink
Its a 2007 BT49-QT9 with a knackered drive belt as its stretched and too loose. Got one off ebay which is far too tight and I cant even stretch it around the engine output shaft so I've gone back to the seller.
How tight a fit should a scooter drive belt be between the rear wheel pully and the engine output shaft ?
Thanks
Stu Very Happy
radical
PostPosted: 22:35 - 20 Jul 2010    Post subject: Reply with quote
You may have to pull or push the pullys apart to get the belt to fit and they are quite a tight fit, emember that the pulleys open and close as the engine revs thus varing the ratios to the back wheel.
stuartadair
PostPosted: 22:48 - 20 Jul 2010    Post subject: Reply with quote
Thanks for the reply. I've just been messing around in the garage and worked it out. Last time I fitted one of these belts (Long time ago) the pulley around the rear wheel was fixed. On this scooter its spring loaded so you've got to pull it apart to fix the belt
Sorted Very Happy
radical
PostPosted: 23:07 - 20 Jul 2010    Post subject: Reply with quote
Nice one Thumbs Up
The last post was made 16 years, 14 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.72 - MySQL Queries: 14 - Page Size: 38.24 Kb
