Installing New Fork Seals - Using home made driver - Guide
silky666
Captain Rulebook
PostPosted: 20:25 - 07 Feb 2010    Post subject: Installing New Fork Seals - Using home made driver - Guide Reply with quote
Although I did this on a set of Kayaba UD Forks from a Yamaha WR400 ... I figure the basic principles will work on any fork.
Certainly beats paying for it to be done and is a lot easier than it seems at first. Thumbs Up
I have made a small video showing the hard bit ... driving the new fork seal into place ... which shows how easy it is using home made tools.
(please excuse the oily hands, grubby fingernails and messy garage):
https://www.youtube.com/watch?v=T-yGhBJYCDk
INSTALLING NEW FORK SEALS ON KAYABA FORKS (YAMAHA WR400)
REMOVING THE FORKS:
?Loosen top yoke pinch bolts ? Keeping the lower yoke bolts done up ? This allows you to easily undo the top cap on the forks.
https://i157.photobucket.com/albums/t69/silky666/Random/removetopcap.jpg
?Remove forks from yokes and loosen the top cap on the forks ? Do not actually remove the top cap at this point.
https://i157.photobucket.com/albums/t69/silky666/Random/undotocapandremove.jpg
?Clean forks thoroughly before taking forks apart ? This makes it easier to stop mud and grit getting into the fork internals when they are apart.
https://i157.photobucket.com/albums/t69/silky666/Random/cleanforks.jpg
?Remove top fork cap ? It will not spring out but hold anyway to stop falling on floor.
https://i157.photobucket.com/albums/t69/silky666/Random/topcapundone.jpg
?Extend fork to maximum and pull down on the spring to see the locking nut ? Use a spanner or lock grips to hold the nut ? And undo the top cap from the fork internals.
?This will take a little effort to crack the thread ? And on mine they then tighten again slightly after 3 turns or so, before undoing fully.
https://i157.photobucket.com/albums/t69/silky666/Random/removetopcapfrominternals.jpg
?At this point it is important to note / write down how each part fits together ? As you will be cleaning them all later on.
?Take off the top cap - Remove inner damping rod ? It will slide out as you tip the fork oil out ? And remove fork spring.
?The rest of the internals will remain inside the lower fork.
?Pour oil out and dispose ? It?s a good idea to let it drain for a while.
https://i157.photobucket.com/albums/t69/silky666/Random/drainoil.jpg
SEPERATING THE FORKS:
?Hold to top of fork and the lower leg ? And pull sharply apart.
?It will feel as if it is catching on something and is unnerving at first ? But this is Simply the internal bushes/washer hitting the fork seal.
?It may take a few good pulls ? But eventually the fork will come apart.
?Note: you cannot break anything here, so give its some effort without worry.
https://i157.photobucket.com/albums/t69/silky666/Random/pullapartfork.jpg
?Remove all of the internal bushes and washers from the lower fork leg ? And remove the old seal.
?Note/Write down the order/ where they go!
?Clean everything.
FITTING THE NEW SEAL:
This is the part that causes the most concern and worry.
However, once you have done it once you will do it with ease every time.
The seal is pressure fitted and you are meant to use the correct seal driver or take it to a bike shop.
But, there is no need. Follow these simple instructions and its as easy as changing an oil filter ! If I can do it, then anyone can!
?Once everything is clean and ready ? make sure you have all of your tools at hand. You will need:
a)2 pieces of A4 paper.
b)Sellotape
c)Hammer
d)Seal Driver (Old fork seal cut in half)
e)Seal grease
f)Plastic bag
g)Fork oil
MAKING THE FORK SEAL DRIVER:
?Take old fork seal and cut in half.
?Make sure that it is slightly less than half of one side (obviously) so that you can easily put it around the fork leg.
?The metal in the seal is strong and trying to cut it with metal pliers will simply twist them and take an age.(trust me I tried it). So best to cut through with a good hacksaw.
?Make sure that any sharp edges are filed down and the seal driver is clean of filings/grit etc.
https://i157.photobucket.com/albums/t69/silky666/Random/halfsealdriver.jpg
DRIVING THE SEAL INTO PLACE (ALSO SEE VIDEO):
?Take the lower fork leg and put the dust seal and spring clip on.
?Then push them to the bottom of the fork and tape in place to stop them sliding down and getting in the way.
?Take Fork seal and coat inner with seal grease (not just normal grease) or use fork oil.
?Note: fork seal goes on open side up.
?Place plastic bag over top of fork and gently push new fork seal over fork.
?The plastic bag stops the seal getting caught and tearing.
?Push seal to half way down the fork.
?Put on washer and then bushes (coating them in fork oil as you do so).
?Take fork upper and coat the seal mating face with seal grease (not normal grease). This is important as it will prevent the seal degrading and also the aluminium of the fork upper corroding.
?Take for lower and insert in fork upper.
?Gently seat the fork seal into the fork upper - You will notice that it will sit proud.
?Make sure the fork is pulled apart 3/4 of the way, and wrap the lower fork with the paper, and tape in place.
https://i157.photobucket.com/albums/t69/silky666/Random/paperroundleg.jpg
?Now place the fork upside down on a clean and soft surface (wood?).
Do not place on concrete as you will be hammering the fork.
?Lower the fork leg down until the paper hits the seal and stops it going down further.
https://i157.photobucket.com/albums/t69/silky666/Random/paperhitsseal.jpg
?Place home made fork driver against the new seal and gently tap / hammer.
?Make sure you rotate it regularly and keep the seal driving down evenly.
Be patient and it will slowly be driven down into the seat.
https://i157.photobucket.com/albums/t69/silky666/Random/tapsealdown.jpg
?There are 2 signs the seal is seated properly.
1)You will now see the spring clip recess groove clearly.
2)The seal will start to make a distinct metal tap sound as it seats against the metal of the fork upper.
?Rough guide is that if you can clearly see the top and bottom of the spring clip recess, then the seal is in.
COMPLETED / NO NEED TO PAY FOR IT TO BE DONE AGAIN:
?That?s it . All done.
As you will see in the video ? the total time spent actually driving the seal into place is no more than 2 minutes. (Studying the video again and it is actually under 1min 30 seconds per seal)
With the homemade driver, it really is that easy.
?Store home made driver for next time (saves you having to hack another seal in half).
?Reassemble fork spring, damper rod and top cap / Refill fork with new oil as per instructions in your manual.
FILLING WITH FORK OIL:
?Last tip ? when setting the fork oil level ? use a clean and long cable tie.
?Measure the correct depth (from the manual) and mark by cutting a small notch in the cable tie. You can then lower it to the notch and when the oil hits the end of the tie its at the right level (like an oil dipstick in reverse!).
https://i157.photobucket.com/albums/t69/silky666/Random/tieoillevelnotch.jpg
?Reassemble the forks as per your manual.
Each fork type needs certain settings of the damping, oil, etc done. Eg: Some forks (Kayaba) require you to loosen off the damper before tightening the top cap.
The last post was made 16 years, 261 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.43 - MySQL Queries: 14 - Page Size: 37.58 Kb
